GX200 bearing size
If I'm reading this correctly, the problem is this:
If the OP modifies the shaft to 1" while the crankshaft is out of the block, then re-assembly is impossible if the bearing won't fit over the PTO. No?
I think a simple measurement should answer this.
r_chez_08
Should be in the shop...
Cornwall, UK
Crap. Yeah you got it right there ts, i was planning to lathe my damaged crank down to 1/2" then put a sleeve that would be heated up then put on (interference fit, .500 crank, .496 sleeve) and have a 1" shaft for my comet 40 driver to go onto. However as
Honda made their bearings just under an inch, I cannot do this. Instead I will probably go from 1/2" to 3/4" with a shrink sleeve, then make a removable adapter from 3/4" to 1" for the tc.
http://weldingweb.com/showthread.php?p=576183#post576183
r_chez_08
Cornwall, UK
See post no. 27 in link
In future I will be buying genuine hondas...
Bluethunder3320
i was going to weld on my HM80 crankshaft then get it lathed back down, but the machinist/welder i talked to said its not that easy. i could pay him $400-500 to do it... NO.
he did something similar to a harley davidson crankshaft... but by hand with a file... because it didnt fit in the lathe. i cant imagine how much that costed!
i ended up buying a new crankshaft for $100....
I think I have to agree. There is a time to DIY-yer-butt-off, and a time to just "do the deed". I think this is one of those times you oughta check the duct tape at the door...
r_chez_08
Cornwall, UK
Lol. What happened is my tc and adapter fell off, whilst the engine was running, because the crank bolt fell out. I was going to lathe it down to 1/2" and put a sleeve that I would heat up and shrink onto the shaft. Wouldnt this work?
There is no harm in trying, if the crank is dead already.
I may be opening a can of worms here, but why don't you just get another keyway cut on the opposite side of the shaft? (or do you want a 1" crank) Will the crank shaft not function correctly if this is done? Will the current damage weaken it in any way?
