chopper neck
vengeance
so i welded a frame from 1 inch d.o.m.and was wondering if i just put a longbolt with nut on bottom through the trees will it turn i have bearrings but they just fall through to the bottomn
You definitely want bearings in there. Find a way to retain the bearings you have, or come up with another way. Maybe hack the steering head tube and bearings off a bicycle, and scab it in?
TorqueRanger
Easy fix boss
1- Put smaller tube inside to support bearing..
2- Weld in smaller head tube but cut and weld sections onto each to hold bearing
3- Weld in little block to hold bearing..
vengeance
i got the plans from custom minichoppers they are good came with frontend plans but all they say is run a bolt and nut through the front end no bearrings. just seems that when tightened down it wouldnt turn.
TorqueRanger
Well get tapered bearing then..
vengeance
good idea. ive never really built anything before i see i can buy a neck with pressed bearrings but dont want to weld with them in .is there a tool to buy for pressing them in?
post pics of the ride.
U can also use a head set from a mountain bike, it will have the cups, bearings, races and the tube to screw it all together. cut it off of a scrap bike. that what i did.
