Why Does My Masterlink Keep Poping Off?
Mrpinhead11
ebensburg pa
Okay so i made sure theres nothing that could poke the clip thing off and its clear but when i put a new clip on i notice that the old clip is all bent out of wack. just the clip. not the peice that goes behind the clip or the chain peice. so could anyone help me? its extreemly annoying. :mad2: thanks :) if pics are need lemme know.
Bluethunder3320
i never knew why this happened. i guess just poor design? because on everything ive had a master link on it ended up breaking.
i only run chains without them.
I have never had a problem. Make sure that at no point is there interference- a good example of this is if you have changed out a sprocket setscrew for a bolt with a head. Could be hitting. A good rule of practice is to make sure the closed end of the clip leads in the direction of rotation. Installing the clip backwards would mean that the "legs" point forwards.
If the plates are OK, the clip's gotta be hitting something... Maybe even just the dirt?
Mrpinhead11
ebensburg pa
yeah that sounds logical. ive tried both directions for the clip part. it sill does not matter :/ its not like i have a 15hp motor with a #35 chain. its a lil 6.5 preditor hf engine with a #42 chain and a tc.
a couple of Ideas are, wire and silicone.
Securing the clip with silicone.
Wiring on the side plate or clip,
here's a few.
Blazkowiez
Kart Aficionado
Houston, Texas
As long as the master-link is directionally accurate and the alignment is proper I havn't really had much trouble with masterlinks ever breaking, though I always suggest people throw extra ones and a pair of pliers in their on kart tool kit.
Me too. I have also not had a problem. I learned about the directional aspect of masterlinks here on the forum. I also have to agree with the wire used on the masterlink. When I bought my first kart, it had wire on the masterlink.
TorqueRanger
I never use a master link, I just press the other links using the tool below..
Item # 66488
Only: $15.99
Sale: $9.99
fowler
Bullsbrook West Aus
if done properly
yes
what type of kart do u have
is your chain getting quite hot
i know the buggy guys had issues with the motorcylce chain being too short and cooking its self to the point it just falls apart
T'was a joke!
That's okay- I had an offset link detonate because of interference with the head of a bolt I was using as a sprocket setscrew... Duh!
