I recently purchased a Manco go kart with a 3.5 Briggs and Stratton Model #91212 with the "air governor". The kart has one spring that appears to be stretched out to work and binds up. The motor runs but doesn't want to take gas when using the gas pedal...linkage is working...will rev up fine when moving the butterfly.
Does anyone have any pics of the spring/governor set up for the motor above?
Does the governor require one or two springs?
Where do the spring/springs attach as I see several holes that could be mounting points.
Should a spring be attached to the loop in the rod that runs from the butterfly to the plastic piece on the rotating pull start assembly?
Thanks,
Mike
Thanks,
Mike
<- This is the most appropriate one we have. Sorry.
