Big mound of soft dirt - now engine won't start
dragon831
So my son and i were hauling it through a cane field when we suddenly ran over a huge mound of soft dirt. Dirt flew up from under the seats, it was everywhere. The engine immediately cut off. The air filter was covered with dirt so i took it off and tried starting the engine. Didnt work. After a few pulls, I get a loud bang so im sure the spark and fuel is there. Does the air filter have to be on in order for it to run? What other parts do i need to clean? I looked in the carb and it looks fine.
dragon831
i dont understand what you guys are saying, the engine ddint completely stop as soon as i started going over the dirt. i went probably about 20 feet throwing up a crapload of dirt then it stopped. If it is the flywheel key, that's in the inside right?
buckeye
Well inside the shroud. Have you pulled your plug? Make sure you have spark. Then fuel. Carb may have sucked enough dirt that the jets are plugged.
dragon831
every 6-7 pulls it's like a loud backfire, would that mean that the spark is there?
buckeye
Exactly. Make sure there is spark. Cheap first or free first. Basic investigation may reveal the issue.
