What gauges can I put in an air cooled 150 cc go kart?
maq1919
I want to know what gauges I can install on a baja reaction 150 go kart since it has none. the needle gauges are nice but I don't know if the will work. I'd prefer needle gauges but I'll use digital. I need to know how to hook them up. I've never done this before, New to karts.
fowler
Bullsbrook West Aus
speedo
from a bike shop
a tacho
put a wire around the spark plug so it can count sparks
if u realy want a temp gauge
u can put anything u want in but only the first two are the common ones
if u call gauges in a kart common
maq1919
Give me more detail please.
can I hook up any motorcycle tach. How do I hook up the speedo. what temp gauges can I hook up?
You have to find out what you have to work with, and work with it. For example, if you do not have a 12v electrical system, most common gauges are useless to you.
If you have a single-cylinder engine, you can't use a multi-cylinder tach. Further to that, even a tach from a motorcycle engine probably triggers differently, your engine may not support it.
Most temp gauges are meant to be immersed in coolant, and thread into a boss in the engine. You do not have this threaded hole. If you wanted to, you could probably just epoxy it to the cylinder head, but again- got 12 volts?
Basically, what I'm getting at here, is that except for the Tiny Tach mentioned above, and a very expensive racing unit- your gauge choices are almost none and would require some serious thought to adapt to your application- If even possible at all (but mostly not).
I (and others) have managed to make use of a bicycle speedometer. Check this thread- http://www.diygokarts.com/vb/showthread.php?t=7450&highlight=wanna+speedo
maq1919
I'll have to wait until I get it to give you more info.
I dont have the kart yet. I pick it up on saturday.
sexyvicta
you can have a cht guage with thermo couple washer thingy under the sparkplug. Same as on aircooled aircraft and fancy racing karts etc
get one of these and then find some guage to hook it up to...
maq1919
What's a cht gauge where do I get one.
Can yo tell me where to get a wire like that and a temp gauge to hook into it?
maq1919
Got any examples of temp gauges that work?
Need to know where to get it and where to get the wire for it.
sexyvicta
cht= cylinder head temp.
no idea where you would find one.
do you have google on your computer? try using that:D
