Is this true?
I was told today that Briggs engines like my old one need to be started at full throttle. They say it was designed that way.
Is this true?? Or are they talking rubish??
This might verge on silliness, but I have to ask- does yours start? How does it start?
If yours starts in one pull nicely at 1/4 throttle with 1/2 choke, while you recite a Shakespearian soliloquy, then who cares what you were "told"?
fowler
Bullsbrook West Aus
i know our lawn mower has no seperate choke
u have to push the throttle all the way up then past full
this activeates the choke
I thought the same thing. It starts just as well as any other engine. If it is cold I need the choke and a couple of pulls, but warmed up I can just give it one or two pulls with no choke.
This statement came from the Briggs agent, that is why I was questioning it. I thought it sounded a bit off.
fowler has a good point here, I've had some briggs powered lawn mowers that didn't have a separate choke lever, and the only way the choke was activated was by setting the throttle to full high. Those models are probably what your Briggs agent was referring to, not yours.
Im not too sure on the briggs, but Im sure digging the square tube frame bike. r-side drive w/jackshaft, sounds somewhat familiar,:thumbsup: nice ride.
r_chez_08
Should be in the shop...
Cornwall, UK
I know its not briggs, but dont honda engines stock with governor rest with the throttle fully open? So when you start it it is open momunterily?
Bluethunder3320
^^^ i think all engines with governors do this. not sure about the air vane type though like his.
As far as I can remember, before I had hooked up the throttle cable and return spring, when you started it it was fully open for a second or so. I could be wrong though. I am picking the engine up from the small engine shop once again after having them look at it. I hope this will be the last time.
Thanks for all the replies
