Jammed E-Tube
CaptCanadia
Acton, CA USA
Well I was being lazy and trying to get my jet in upside down. It wasn't working so I thought I had the etube backwards. I flipped it and put pressure on the screwdriver. Now the etube is jammed on there backwards. I took the carb off and smacked it like 50000 times and put the new jet in to see if that would loosen it. No luck. I also tried magnetizing my screwdriver and pulling it out but I remembered it isn't magnetic..Anyone have some ideas?
CaptCanadia
Acton, CA USA
Yeah haha. Hey cybord I put a new air filter and I don't have that tube going into the OHV anymore. That can be left open right?
devino246
Official DIYGK Chem Nerd
Lynchburg, VA
I hope you dont work on cars:eek:ut: If its not going it, dont force it.
You do need a tube there. Just get about 12-18 inches of tube and stick it in your "OHV" (thats the valve cover).
CaptCanadia
Acton, CA USA
Hahaha ya good thing. I didn't jam it though I just dropped it in and it jammed sideways or something. It turned out to be the right way anyways. Can I just put the old tube in there from the airbox?
r_chez_08
Should be in the shop...
Cornwall, UK
You can use a small filter for about $3 from ebay or a fuel filter. Getting a $15 uni filter from AGK is way overkill.
Bluethunder3320
yup.
but how do you explain this? some engines dont have that tube plugged in, factory.
Everyone makes mistakes, even stupid ones. That's one of the ways you learn
While that is undeniably true, it is so much more efficient (learn more, faster) to skip the the easily avoidable and potentially costly mistakes with research.
For example- You could install a spark plug with a sledgehammer, which would ultimately result in learning not to do so. It will also waste your time, and cost you (at the very least) the price of a new spark plug. Having a quick look at a service manual might save you the time, money, and hassle- and you'd learn the same thing.
No?
As a matter of curiosity, how much time did you lose fooling around with the emulsion tube and main jet? Were you LUCKY enough to avoid damaging anything while you were at it?
Please note that I'm not trying to bust your hump for kicks. I just feel that there's a thing or two to be learned here.
CaptCanadia
Acton, CA USA
lol i broke one of the fins on the main jet when i tried to rebuild my carb so i cant get it out and its clogged... so i basically effd up my carb,
Aw dude that sucks.
Well I'm glad you told me that toystory. In the future I'll try not to waste so much time and actually make sure I know what I'm doing beforehand! Thank you.
machinist@large
West Michigan, 49331
He wasn't trying to be facetious, he was trying to explane that a good manual can give you the answer before you think of the question. Even better, is will have pictures to go with the descriptions. It's the same reason so many questions on this site are responded to with the request for pictures; so the rest of us can see what you are trying to describe/ ask about.
Clearly, you're not familiar with the saying, "Give a man a fish, and you feed him for a day. Teach a man to fish, and you feed him for life". Was just trying to teach you to fish. Sorry.
