fram fuel filter
MisterRoboto
i got this fram filter at walmart today to put in my line for my h40 tecumseh but my brother is afraid that without a fuel pump the fuel wont get pushed/pulled through it? anyone know if it will be ok or not?
ty
kendelrk
redneck engineer
westland michigan
it will be perfectly fine, what a fuel filter does is just run the fuel through a filter to keep it clean, yeah after you install it it might take a few pulls to start, thats just pulling the gas through the line, once there it pushes right thru the filter, no problems, so dont worry and install your filter
devino246
Official DIYGK Chem Nerd
Lynchburg, VA
If it doesnt have a fuel pump, pulling the engine over has no effect on fuel getting down to the carb.
There shouldnt be any problem.
Wow. Glad you clarified that.
For the record, you can pull your arm off, it really won't have a significant effect on drawing fuel through the line. The engine's vacuum does not act in direct correlation to the fuel flow. Think- Bowl, float, inlet needle. What will "push" fuel through a filter is either gravity, or a fuel pump.
At any rate, I think that filter has a large enough surface area over a coarse enough media that it will be okay. An unltra-fine media over a smaller surface area would require more force/vacuum to allow flow.
