which engine is the better choice?
mini chopper
long island
okay so im building a small buggy, i have to engine options, the first being a yz250f, the second a kx250. which do you think would suite me better for off roading? or if i was to build a shifter kart, with a race chassis and everything, which would be better?
CaptCanadia
Acton, CA USA
I think he wants the engine to be easily modified as well. From Bing searches I think the yz is easier to modify. You'd have to look more into yourself though.
mini chopper
long island
not really the HP, but how will it perform? will the 4 stroke have more low end than the 2 stroke? i mean a 10 Hp difference is pretty big and i would take that. plus a 2 stroke is lighter. so i think im going to take the kx, i was just looking for your opinion as to what engine you would use if it was your kart
DCProductions
Cockney Ragamuffin
Louisiana, USA
You can gear a 2 stroke to perform reasonably well at low end, but I see your issue. I didn't even see that those two engines were different strokes! I still think that 8 more hp can compensate for any advantages the 4 stroke has.
With a race chassis, I'd suggest using a honda CR125. Hardly any racekart tracks in the USA allow engines over 125cc. to compete (and this model engine is by far the most commonly used so its easy to find all the special parts you'd need like motor mounts, pipes etcetera).
So using any 250cc would eliminate any chance of racing at a track and also lower your karts potential resale value. A CR125 shifter racekart would be so fast you wouldnt believe it.
I'd go with the 4-stroke on the buggy for grunt, and the 2-stroke on the race chassis for light weight and speed.
machinist@large
West Michigan, 49331
how do they have less torque? they fire every time opposed to every other time? shouldnt that equal more torque?
You are confusing torque with horsepower; they are related, but different. Torque is what actually moves the load; horsepower is the rate at which the work is getting done.
In your question you asked if firing on every turn of the crank = more torque. Somewhat. what it really makes is more HP (rate at which work is being done).:thumbsup:
DCProductions
Cockney Ragamuffin
Louisiana, USA
The gas does not produce as much "oomph" because it is mixed with oil. Also compressions are different, but because it fires every stroke, it can achieve higher rpm and in most cases, higher hp than a comparable displacement 4 stroke.
