Honda 70 china clone No fire
osso12
Kartman
Mesquite Texas
I have this toy I got from a customer that did not want it.
I have about $180 in parts on it that I have spent.
It is fun. It has a 4 speed gear box, no clutch.
I have been riding it for about a week.
When I got the kart, there was no key, broken ignition switch, and dead battery.
I hooked a green and orange wire together and jumped it off with my car and it fired right up! Been riding the heck out of it.
Last week I decided to put a new battery, and key switch on it.
Put the battery on, jumped the starter over but no crank.
wtf?
So I went ahead and hooked up the ignition switch..
same thing...turns over no crank....
I check for fire from the plug...
No fire...HUM...
Must have fire for it to run right?
So I replace the plug. No fire.
Unhook everything I did to the switch and got it back to where it was when I got it. Two bare black wires ( i assume kill switch)
a orange wire, and a green wire, and two red leads with 12 volts and the other going to the starter.
I leave the black wires unhooked. I put the orange wire and the green wire together, all indicator shifter lights light up on the dash so I assume we have 12 volts going to the sytem.
I can assume the orange wire goes back to the solenoid as it is always hot. I assume the green wire goes to the coil.
Now here is what I did today. I ordered a new CDI box, and a new coil, and a new plug.
I start with the new plug. No fire. I change out the CDI box.
No fire. I replace the coil. No fire.
I checked the Stator three of four days ago. No debris and it looks to be good, no burn marks etc.
There is nothing left but the stator to replace. What gives?
is there maybe something simple I am over looking?
This is driving me nuts!
:mad2:
Either someone help me fix this or they are gonna get a helluva deal on a dragster 70 cc go kart.
Here are some pics for your amusement while we figure this out.
:idea2:
:ack2:
osso12
Kartman
Mesquite Texas
ummm...can you show me a pic of what it looks like?
This china stuff is greek to me. Im used to hot wiring big block chevys easier...LOL
osso12
Kartman
Mesquite Texas
Did you hook anything up backwards maybe and then fry something?
:D
I did ground out the orange wire I believe to a contact on the switch when I was trying to connect the switch.
Small arc, very small tiny puff of smoke. The orange wire burned about the first half inch of insulation off and I cut off the burned end and respliced. I followed the wire harness down and far as I could and did not see any other warm areas or burned insulation.
But you may be on to something as I have not got it to fire since.
:mad2:
fowler
Bullsbrook West Aus
lol true that
i assume it turns over
i assume u hace checked the fuse box
it should have a fuse box
u may have gounded the wrong thing
the-cyborg
Spring, Texas
Pull the plug wire look in the cap you should see something that looks like a brass jet from a carb, unscrew it being careful it is spring loaded there should be a thing that resembles a fuse, find a screw the same length, or another resister, its a long shot, but these little suckers has made me pull my hair out more than once.
osso12
Kartman
Mesquite Texas
I put a new coil on it already still no spark?
Im confused.
the-cyborg
Spring, Texas
I would disconnect anything going to the coil that is going to the ignition switch, and see if I could get fire that way.
There's only just so may things that cause no spark.
eliminate everything but the coil and cdi down to the bare essentials, see it it will fire, the work your way out till you find it.
osso12
Kartman
Mesquite Texas
here is where I need to be careful. I guess I can try this with the old coil. There are two leads to the coil.
A solid green wire ( I assume this is hot from battery?)
and a black/Yellow wire. I assume the black/yellow lead is probably a kill back up to the switch if there was a kill switch which there is not a kill switch at the moment, just a open wire that is not connected. :toetap05:
If I run 12 volts to the green wire from the battery, is there any danger of shorting this coil?
This would be the same as hot wiring any car. I do not want to burn the coil out though by being hasty.
the-cyborg
Spring, Texas
It is magneto ignition ?
or is it some weird electronic ignition.
You should at least be able to get a spark every time the magnets pass the iron coil with nothing connected to it.
