I'm currently running a 6.5 HP Honda GX200 (governed at 3600 rpm)with a torque converter and a jack shaft. There is a 10 tooth sprocket on the jack shaft and a 72 tooth sprocket on the axle, and 20" diameter rear tires. (see picture below) I'm assuming when the kart is at top speed the torque converter should give me a 1 to 1 ratio. The speed calculator says I should be getting about 30 mph, but I'm only getting about 20 mph according to the GPS on my phone.
I had the kart when I was a kid, and just got the thing going for the first time in about 10 years about a month ago. I've installed a tiny tach and it's reading very close to 3600 rpms. I'm a quite a bit fatter than I was when I was a kid (weigh about 200 lbs now) but I do remember it going closer to 30 then. Is there something wrong with my torque converter, do I need to gear it lower because I weight more, or what could be wrong?
Also, in the very near future I do plan on removing the governor, and installing a billet rod, flywheel, 16# valve springs, new intake and exhaust, and rejetting the carb. Will I need to gear it differently or am I ok? I'd like to be able to go closer to 45-50 mph and still have some low end power for climbing small inclines, etc.
