I Searched But.....
strang
Gaston County, NC
found nothing :mad2:
I have a B&S 5hp flathead on a Streaker kart.
The clutch that is on there still has some life in it but I want to go ahead and order a replacement BEFORE the old one craps out.
All I know about the old clutch (without taking it off) is:
1. it has 10 teeth
2. The chain is a 420
What I need to know is what type of new clutch? What is the shaft diameter on my flathead?
Is it 3/4"?
If so, would a 10t for a 40 chain clutch work?
Eventually I'd like to put a TC on it but I believe the motor would have to be shifted over and/or a jackshaft and mounts installed/fabricated.... am i right?
the-cyborg
Spring, Texas
1. it has 10 teeth
Is it 3/4"?
3/4 bore #40/41 pitch will work
r97
Measure twice cut once
Massachusetts, USA
its probably a 3/4" shaft, but is it really going to kill you to at the least take the little bolt off the end on the crank to measure it? (assuming it has a bolt, even so, its not too hard). i know i would be kicking myself if i had ordered a wrong part just because i was too lazy to measure something simple.
Most 5hp briggs kart engines have 3/4" output shafts, but I saw one that had a 1".
I'd suggest you take a minute to measure yours before ordering your clutch.
strang
Gaston County, NC
I will, thanks.
Right now I have my neighbor doing a basic tune-up on the flathead (air filter, plug, oil change, carburetor cleaning, etc)
<strang and pondering a turbocharger......> :D
redsox985
PA
You're going to need a tiny turbo for that. Look up Lemegacool's turbo shopping kart.
