How to replace this clutch?
rubbish21
My clutch is fried, the teeth broke off. My problem is I'm not sure how to get the rest of the clutch off the crankshaft. Detail: Subaru Robin EX13, 5HP. I don't see any place to use an Allen wrench to remove the rest. Any ideas?
Blazkowiez
Kart Aficionado
Houston, Texas
You still have a key to remove, perhaps set screws, and usually it needs to be pried off using a pickle fork or pry bar. In the past when they're really bad we've had to carefully cut it off using a torch. Its not Hilliard, that design is MaxTorque or Comet.
HellSpawn
Wadena, Minnesota
I've found that an air chissle with a dulled end works perfect for getting close tolerance sleeves and other things like this off. Just give it a couple quick zaps and it expands enough to the point where it just falls off. w/ zero damage to the shaft. Works great for old rusty nuts that wont budge, although I tend to use a sharper end for those and just split them.
r_chez_08
Should be in the shop...
Cornwall, UK
If you can find the brand of the clutch, you could just buy a new drum and not worry about spoiling the rest of the clutch removing it.
rubbish21
Resolved. Following up to close this one out: I had some "Break Free" spray that I used instead of the suggested PB Blaster. I sprayed it into the keyhole and anywhere else that I thought I could get it. Nothing -- I tried everything to pull it off, it would not budge. It finally took me using a hacksaw to cut over the keyhole area, that allowed me to then use pliers to break some away, the whole unit loosened up and then slid off.
