I'm new to the EV scene and I'm pretty electrically illiterate so I need your help. My project is an electric go-kart which is going to use a 36V brushless DC motor (rated power: 10kW, rated current: 250A, weight: 18lbs). After days of scouring the web I've found three battery options: Li-ion(a123), LiFePO4, and good old LA. I'd like to stay away from LA due to the weight factor even though they're cheapest. My LiFePO4 options are as follows:
Thunder Sky: 3.2V 12 in series, rated at 60Ah OR the 90Ah version
Lightning Bolt: 3.2V 12s, rated at 50Ah OR the 100Ah version
My understanding is that I would also need some sort of BMS. The other option was to make a a123 Li-ion pack(or have made). The configuration I was considering is below:
3.3V, 12s4P which would give me a capacity of 9.2Ah at 30C
The Li-ion is most attractive to me but would that configuration be capable of running a go-kart for a decent amount of time, or at all because of the low capacity? Does anyone else have a suggestion on battery type/config?
