Briggs and stratton yard machines 5hp
Russ2251
AZUSA:Powered by LAWN-BOY
Yes.
Bicycle brake cable and housing works good for me.
Connect between accelerator pedal and carb linkage...lock down cable housing so that only inner cable moves with depression of pedal...Done.
xcorvettekid06x
I didn't know if there was anywhere to be ae to hook the throttle cable because the throttle on the motor doesn't feel like it has any kind of spring back for when I let go of the gas. Any ideas? And also the cart already has a sproket on it hoe can I tell what size chain I need?
j.concepcion54321
Rebuilding KTM, Need Kart
East Providence RI
if you post some pictures up of your engine someone else will chime in and let you know how theyd do it. is the throttle arm exposed like on a clone engine? orare you hooking itstraight up to the carb?
You'll need to buy a spring at a hardware store and install it so its pulling your throttle linkage back to the Idle position.
I'd suggest you also buy a second spring and install it on your gas pedal, so it pulls the pedal back up to the Idle position.
If you posted some good pics of your engines throttle linkage we could give you more detailed info, but check out the info in this link too:--> http://www.diygokarts.com/vb/showthread.php?t=10036
We can tell you but you need to accurately measure and let us know the distance between the tips of 2 of its teeth, and then also let us know how thick the sprocket is.
j.concepcion54321
East Providence RI
I must have misunderstood the question.
Well he said if he could use it in the first post and then he asked if the throttle could be hooked up and how to do it. so he does need a clutch to use it. thats what i understood that he was asking 2 questions. and i was correct since he proceeded to wonder about the chain size, type of clutch, etc.
xcorvettekid06x
Well now my starter rope broke and the cover was riveted on and me not thinking drilled the rivets out with the starter still on. And the engines flooded. Help please. I'm very new to small motors. I know car motors mostly.
