Crankshaft Help!
j.concepcion54321
Rebuilding KTM, Need Kart
East Providence RI
Hey guys I need help finding a new crankshaft for my briggs and stratton engine. I was originally thinkig of just selling it for parts but then i figured that i might as well fix it myself seeing as it runs. ive tried looking around but i havent been able to find any numbers on the crankshaft. Also the crankshaft is 1 inch which is rare for a 5hp engine. Heres the specs of the engine.
Model: 30212
Type: 31201
Also i have a picture attached of the engine. If someone would please be able to help me find the exact crankshaft i would GREATLY appreciate it.
Thanks,
J.concepcion54321
j.concepcion54321
East Providence RI
yeah it bent, I have a thread about it somewhere on this site. It was on a log shredder and it got jammed up and flew straight out of the machine. (Or so i was told when i bought it) It was bent ever since. i had originally planned on taking it to a machine shop to get it straightened out, but that idea was shot out of the sky rather quickly. So i figured id sell it for parts but then i realized that i might as well fix it up. So now i neeed a crankshaft. I looked for about an hour and couldnt find anything so i figured one of you guys who is better with computers would be able to find me something
r97
Measure twice cut once
Massachusetts, USA
I'm 99% sure this should work, but for $88, its not really worth it for an engine you could buy for $40.... you should take it to a machine shop, have them put it on a lathe and turn it down to 3/4", that way it uses a standard clutch, and is straight!
the reason you were having trouble is because it's a briggs manufactured for craftsman, so sears has all the parts, manuals, and information locked up, makes it a pain in the butt!
http://www.searspartsdirect.com/partsdirect/part-model/30212?searchModPar=30212&pathTaken=modelSearch&prst=0&shdMod=30212
http://www.jackssmallengines.com/searchresults.cfm?cx=008737122150761418589%3Ac24nnqwh7co&cof=FORID%3A11&q=397104&sa.x=0&sa.y=0
j.concepcion54321
East Providence RI
how would turning it down make it straight?? wouldnt it just have the same problem and wobble even though its 3/4??
r97
Massachusetts, USA
well as long as the bend is on the part of the shaft you would be turning down to 3/4", and the shaft hasn't bent more than 1/8", it should make a perfectly strait 3/4" crank. (even if it is bent more than 1/8", once turned down on the lathe it will will just make the shaft kinda screwed up, but still straight and usable)
i can't really explain how it will fix the problem, but it should. i will mention that you might make the threads on the crank useless. also, i'm not sure if there is an issue with turning unbalanced stuff on a lathe.
whats wrong with having the machine shop just straighten the shaft, you could rig up a belt tensioner clutch cheaply and easily.
j.concepcion54321
East Providence RI
well i can get a nice 6.5hp briggs and stratton intek engine from a friend for 40 bucks all day long. just gotta get the cash. so i figured if it would cost more to fix this engine then its not worth it
crazyman
Yorkville Il
I straighten bent vertical shafts often. Bolt that sucker down to something, pull the plug, and roll the motor over to find the high spot and keep whacking and repeating with a big hammer until it's straight. You may have to dress the end with a file to clean up the mushrooming, but it's worth a shot to try fixing it for free.
Bluethunder3320
i wouldnt do that without removing the shaft..... bending a solid steel 1" bar takes alot of force, it would easily crack the thin aluminum cases...
