Honda 50r
bighead
Pacific Northwest USA
Starts and runs fine. After about 10 to 15 minutes it starts missing and sputtering. Let cool off and it does it all ove again.
Things I done so far with no luck.
I cleaned the carb
cleaned points
Burped and check gas cap vent
cleaned filter
New fuel filter
Besides that I have not done anything else.
Any tips for a fix? It's the little 4 stroke 50 you see in the back. Trying to get it running right for 4th of July parade.
Thanks
karl
North east Ohio
Coil. When they heat up they quit. That cool down and they will work again. Happened on a 1978 jag snowmobile and 3hp briggs.
number 37
+1
might can check the coil output at first start up and compare to when it starts to die
Yeah I've seen ignition systems that only start to malfunction after running for a bit too, Intermittent problems like this are tough to diagnose.
Hey Is that a 4 cycle?
If so, maybe your valve lash is adjusted a little too tight, and fully warming it up causes something to expand worsening the issue. You could do a compression test when cold and then another after it fully warms up and starts missing. Then If your 2nd test reading is quite a bit lower you'll be getting a good clue that might just be your problem...
bighead
Yeah I've seen ignition systems that only start to malfunction after running for a bit too, problems like this are aggravating to diagnose.
I found a great vid on how to adjust the valves. It really simple and easy on this bike. Yes it is a 4 stroke. I will try that first.
http://www.youtube.com/watch?v=HppcqVpnaFw&feature=channel_video_title
bighead
Ok I replaced the coil and it still runs like crap after 10 minutes.
I was told it may be the coil. What coil? The coil on the stator or the main coil? I changed the coil and spark plug boot and wire. No change.
I will adjust the valves next. Hope thats the problem now.
To refresh you. It starts right up and runs great. about 10 minutes later it start sputtering and missing. Then finaly just dies and will not run. Let cool and all over again...
Any tips?
Bluethunder3320
my guess is the valves, because of heat expansion, once the engine gets hot, the valves arent seating right.? maybe? because they are too "long" and wont fully close.
r_chez_08
Should be in the shop...
Cornwall, UK
Dang b man, i was about to say that :)
Maybe you have a blockage somewhere so the fuel is just dripping through, so it fulls up the bowl after sitting for a while (cooling down) and the after 10 minutes it has ran out.
bighead
Well the carb has been cleaned by me. New fuel line and filter.
Is it the Pulse coil on the stator or the main coil that can go bad and act like this?
I got to adjust the valves. It will only take about 15 minutes. We will go from there.
I forgot to check the gas tank vent. Perhaps thats it. Could well be thinking about it more....
kendelrk
redneck engineer
westland michigan
do yourself a favor big head, pull the carb off, open her up and put the fuel line on, see if its getting fuel, i had this problem with my clone, it dripped slow in the bowl, then once it ran out, sputtered, died off, not to start again,
bighead
I just put a clear fuel filter on. After dinner I will go mess with it. I am going to check the vent first. Common problem to what I am having. I now think the vent is not letting any fuel down. Airlock of what ever you call it. If that does not work then tomorrow when the bike is cold I will adjust the valves. If that does not work I will look to do what you said and dig further.
I am betting it's the vent now. I do not know how I missed trying that.
One by one I will nail this down.
