here we go again
kendelrk
redneck engineer
westland michigan
so now that i got my tecumseh working right, i took it out for a small test drive around the block, the engine worked well, the cart didnt, the brake cable snapped, so theres no brakes, and the steering is squeaking, and sounds like its about to fall apart, plus a small banging noise when im riding coming from the cart, what can i do to fix thesse?
You examine each problem individually, find the issue, and solve it. For example- telling me your steering squeaks and how should you fix it. Put the kart up on stands and keep working the steering until you find the squeak. Odds are good that some maintenance is in order, by way of a well-placed lubricant.
Brake cable snapped? Replace it.
You get the idea, yes?
Big Boy
Noob!
New York
i couldnt do that russ, id be bored out of my mind, and i love karts, and mini bikes, i cant stay away from them
So why wouldnt you enjoy working on them? Thats part of the fun. If something breaks and you fix it yourself, its a good feeling.
B man
Tecumseh FTW!
Oliver springs,Tn
i do enjoy it, i just get frustrated after a few days, and yeah i do russ, its like ha, i told you i could fix it
i know. my dad thought my TC's belt was to short because the kart kept running away. and he argued that for 3 days straight.and he wouldn't let me touch it. so when he finally did after he said "your still won't make it work" so about 5min later he came out to check on me cause he heard the engine running. he saw it sitting there and and asked "how did you do that?" i said, "well i lowered the idle and sanded the TC faces" then i said "ha you where wrong" and i went on gloating all day and he finally said "OK i get it im wrong" it felt so good.
mikegrundvig
I personally hate the "break, fix, repeat" cycle a great deal and so I generally over-design and over-build - it's heavy and more expensive but generally quite reliable. If you can do it, you can always over do it :)
-Mike
I'm usually guilty of overengineering, too. But the nature of DIY often means stepping into the unknown when tackling a project. Despite any egos anyone may have, nobody ever always nails it the first time through. Furthermore, since DIY often involves components of unknown/questionable origin or history, there's going to be an inevitable element of surprise. Example- You just bought a 30-year old flatty on Craigslist for $20. You just gave it the once over- compression, spark, fuel, air. Cleaned and gapped plug, fresh fuel, one pull- vroom! Satisfied with your new purchase, you bolt it to Betsy there, and go for a shakedown run. BOOM! Bottom end lets go. You couldn't possibly have known that the previous owner to the previous owner had torn it down and when reassembling, torqued the rod cap nuts to "feels right", and put 'er back together...
The above example was straight out of my imagination, but happens all the time. The lesson to be had here is that it's par for the course, and you'd basically better get used to the idea. Your only other option is blow a couple of grand on something factory built, shiny new, and comes complete with a warranty...
