at what point do you rename/title something
rabies
punching kittens
iowa
i have a build thread and im not sure what to call it now.
some call it a go kart.
a larger version is a sand rail.
a much larger version is a rock crawler yes?
each is different i know.
but are there any specific terms for dif kinds of karts? :confused:
shifter kart
go kart
vintage kart ??
The lines of definition can be a bit blurry. In my mind,
Vintage is Vintage, no explanation required.
Classic- Not necessarily vintage, but of the same style. likely 1wd but could be live axle, quite small and light, rear engine, centrifugal clutch, no cage. Seat back support hoop maybe, but not likely to have a "roll" hoop. Generally small, pavement-oriented tires.
Race- self explanatory. Can be a shifter or fixed gear
Shifter- techincally a race term, but can generally refer to any kart with a multiple gear, manual transmission.
Yard/fun kart- probably the most common. 1wd or live axle, can have multiple engine/ drive arrangements, can have a roll hoop or cage, can have suspension of varying designs. Personally, I use this term to describe factory manufactured machines. For the home brew stuff, I tend to just use "onroad" or "offroad".
Buggy- I use this term to describe any "kart" that has 1) an engine OTHER than a single-cylinder industrial engine, 2) a roll hoop or cage, and 3) front and rear suspension.
Sand rails and rockcrawlers are two very specific vehicles. Both use Automotive/Light truck components and are built for a very specific task.
To use myself as an example. I started with an "offroad kart" by my own definition. I have built front suspension. Still an "offroad kart". I have removed the Honda GX340 11hp and will be replacing it with a 250 motorcycle engine. Still an offroad kart. After that, I'm building rear suspension. Now it's a buggy...
This is the way I see things.
One other thing- I have a tendency to say "go kart" referring to a classic, vintage, or race kart. Whereas I tend to use "kart" to refer to any of the others. Probably my way of paying respect to the true definition of "go kart"...
JHen
The terms are used pretty loosely in general, except sand rail and rock crawler. A sand rail is a full cage vehicle meant for rolling sand dunes. They use paddle tires. A rock crawler is a 4x4 vehicle with huge tires and extreme travel suspension so they can roll over big boulders and not care.
A go kart to me is small car without a roll cage. Add a roll cage, and it becomes a buggy.
bighead
Pacific Northwest USA
I agree with this. But I add Mini Buggy to the fold. I call the high doller buggies mini buggies. And Buggy as you stated above.
So I guess the Honda Odyssey is a Glorified Yard Kart. :D
fowler
Bullsbrook West Aus
id call my 250 project and the oddy a buggy based on the fact they have motorcycle or snow mobil engines and they are cabable of high speeds off road
they also dont function well on road
a gokart as a typical yard kart
a race kart as a race kart with industrial engine
shifter as a race kart with bike engine
and a minni buggy as somthing like a piranha or barracuda, build as a small sand rail
very fast off road
very high power to wieght ratio
slower than a sand rail but
the lines start to blur when people put 13hp clones in a frame with full indipendant suspension
just anouther opinion
oldbikerarlo
Old guy
Marana, Az.
To me a go kart has no suspension, single cylinder engine, road or dirt tires, maybe a roll hoop (no cage) and some engineering in the steering. classic and vintage race.
Engine seat, side by side is a race kart.
It becomes a yard kart or fun kart when it has a two wide seat and cage, turf tires, and simple with no thought to correct steering.
Anything with suspension becomes a buggie or mini buggy. Just my opinion.
:ack2:
