i may have to try this!
karl
North east Ohio
I might make one for my lawnmower lol. 2 vertical shaft 3.5hp classics lol. I got 2 3hp horizontal shaft briggs and a 6hp Tecumseh carb lying around. I should do it and make a light racing cart.
r97
Measure twice cut once
Massachusetts, USA
Thats awesome! Does he have 2 ignition coils too?
it says it uses an ignition coil from a 2 cylinder engine.
A whole 2hp. at about 70 lbs.
it only uses two 1.1hp engines, and from what i can see one standard carb.
http://www.briggsandstratton.com/pdf/owners_manual/100/Model 5S-Domestic.pdf
no, it wouldn't have an insane power to weight ratio, but with many of the parts from the second engine removed, a larger carb, and using larger engines, it would be very powerful, and look cool! possibly run smoother no? i would think it would at least have a better power/weight ratio than a twin engine kart.
r97
Massachusetts, USA
beat me to it! i wanna see this thing in a "drift trike" or something! although a lawn mower would be cool too!
r97
Massachusetts, USA
pretty nice
wonder what he did about the crank
i would bet he either machined the shafts to mate, or bolted them togther, or maybe even welded them. the best option would probably be to make an adapter, which he may have done.
r97
Massachusetts, USA
:iagree:
but on a moving vehicle, with proper ducting, it would probably be ok, you could always add another low profile fan on the PTO.
r97
Massachusetts, USA
russ probably likes the power/weight of this one better. takes up a ton of room on a kart though, would need to be side mounted, or put in a mini bike/chopper.
http://www.youtube.com/watch?v=ANJ6a8w9-Cs&feature=related
this one is cool too, some insane compression, but heavy and would have a complicated drive system... still awesome,
http://www.youtube.com/watch?v=yMX2rH6F5jc&feature=related
running,
http://www.youtube.com/watch?v=fM3m6S0A56U&feature=related
some day i'm going to buy a ton of engines and do everything i can think of to them! flat four? LOL
JHen
Just take two engines, pull the recoil start off of one and attach a coupler that would couple the crankshaft of one to where the recoil start was on the other, just make the key ways 180 degress apart. This would give you a power stroke every other rotation. Both engines would have to turn the same direction. Simplest way to go about it. Might be a tad hard to start by hand though.
You would either have to have one carb and make a piping system to go to both engines, or set up a linkage to operate both carbs.
r97
Massachusetts, USA
no offense man, but your taking all the fun out of it! LOL
besides, the first design would:
-be more fun to make
-look cooler
-weigh less
-take up less space
if your going to just connect them you min as well just run a normal twin engine kinda thing.
