wooley
Total Noob
My grandson has had his Carter 2235-1015, 5hp kart for 4 days and it's time to get the cut-off wheel and welder out. I would like to
1. Improve traction in the sand with wider tires and a live axle.
2. ~Halve the top speed and increase the low end.
Partly because I'm clueless, I'm not entirely sure where to start.
The kart has 14.5x7-6 knobby tires on all four corners. I’d like something wider and better in the sand. I haven’t found anything wider for 6-inch rims though. Would it help to move up to 18x9.50-8? That will compound my problem of reducing the speed and increasing the torque though. Is there a wider than 7 inch tire out there for 6-inch rims? Or something you recommend?
The drive train is a centrifugal belt clutch to a 5-¾ inch pulley on the 3/4-inch jackshaft. The other end of the jackshaft is a 12-tooth drive gear to a 60-tooth driven sprocket. The chain is #41. I found the gearing calculator posted by someone (thanks!) but hope that one of you might know what parts are available and compatible to gear this thing down. If I mount a larger driven pulley on the engine side of the jackshaft and a 10-tooth drive sprocket on the other end of the jackshaft what would be the result?
I haven’t found anything about changing from a belt clutch to a sprocket clutch and I’m not sure what that would do to the alignment of everything but it may make it easier to reduce the gearing.
I’ve looked at several threads for converting to a live axle and think there will one and some pillow blocks and bearings in the mail this week.
If anyone has any suggestions I would welcome them.
