What's a jackshaft??????
Joeyk99
I was looking at a torque converter and it said that it replaced a jackshaft and I have no idea what that is can someone help me!!!!???
It is used to change the plane of drive, typically with a motor to have a right side drive. on mine this is what I did. In this pic the guard wasn't fully atached yet.
In addition-
They are often used to create a gear reduction ratio that would be impossible or impractical without. For example, a 10:1 ratio can be reached with a 10T engine sprocket and a 100T axle sprocket. But that axle sprocket would be huge! The tire wouldn't touch the ground because of it. So- jackshaft. 10T on the engine and 20T on the "in" side of the jackshaft. Then a 10T on the "out" side of the jackshaft to a 50T on the axle. Same overall ratio, axle sprocket is half the size.
Jackshafts can also be used to go from belt to chain drive or vise-versa.
oh ya I forgot to mention those aswell, definitely on changing gear ratio is much easier. just swap the sprocket out for the right one.
Joeyk99
and also how does a torque converter work/what does it do/how does it connect with the driveshaft and chain??
