Streaker 8HP Go Kart with Torque Converter
Which engine
  • Total voters
    11
South Kart3377
Kart designer
Va
Ok, My Dad bought Me a Streaker Go Kart!
What type of torque converter is it???
What should I get for front tires???
Will be using OFF-ROAD!!!
It has 22in. back tires.
What battery should I get for the light and e-start???
8HP Briggs engine:wai:
What tc belt do I need???
gokart14
Nebraska
is there even a front end????????
Pull it out of the weeds doesnt really look like u bought it looks like it has been sitten there for some time
South Kart3377
Kart designer
Va
Yes, there is a front end!:mad2: Just needs front tires.:thumbsup: Those are just pre-resteration pics. Only been there 1 month. The car beside it has been there for 4 years!!! The old owner droped it there, so we could pick it up.
redsox985
PA
It's gonna need a lot before it is up and running. You will need to sand the TC faces, get a new chain or preform electrolysis on the current one, and probably clean the TC and carb. I think it has a 40 series TC judging by the look of the driver and that the driven is mounted inboard. You will need to reset the driven also, and maybe install new buttons. The belt needed will be determined by the distance from the center of the motor PTO to the center of the JS. Measure accurately to the 16th of an inch.
South Kart3377
Kart designer
Va
Carb near perfect. Thanks:thumbsup:
B man
Tecumseh FTW!
Oliver springs,Tn
pull it out and asses the frame. check for cracks. clean it up and put on some front tires.
then re take pics.
j.concepcion54321
Rebuilding KTM, Need Kart
East Providence RI
pull it out of the weeds and take some better pics. after you get the new wheels and belt go for a test drive and see how she feels. then youll know what other mods youll have to do to the kart. better seat, suspension, tires, engine, speed, torque, etc. But dont change anything until you ride it first. you might eff it up like i did on my first kart. ;D
South Kart3377
Kart designer
Va
Fixed pull starter today, cleaned carb, and got 16in tires for extras!!!!! Still need belt!!!!!
