a freebe
bobby28
hello i would like to interduce myself my name is bobby.i have a yerf-dog 3202 that i need some help with its in the stering and tow i have pics for you to look at too try too help me thx bobby
bighead
Pacific Northwest USA
Maybe some wore out shocks. That was the case with the one I had. Post a pic with no one in it.
The shocks should some adjustment on them. What setting are they set at?
bobby28
im set in the 2 hole for the shocks i have pics with noone in the cart but i cant get them right now will have them tomarow
gokart14
Nebraska
the shock itself can be tightened not what hole it is in. look at the shock u can move it so it gets tighter that will tighten the shock
bobby28
i tighted the shock it makes no diffrence. my outher problem im having is when i turn the stering wheel my tires hit the frame. can someone get me the mesurments from the frame too the a arm on a yefr dog 3202 or something simerler
bighead
Ya you can still buy those front end parts. Look on ebay for yerfdog a-arms and spindles. I have found that the bracket will bend before the spindles will. If the spindles are bent I would bet my pay check that the bracket is as well. Not sure if they have the spindles. But they have the a-arm and the spindle bracket that you can weld in yourself.
I have these karts before. The bracket on the a-arm will break easy. Looks for cracks or bends there. Also take the wheels off. line the pitman arm so it is facing down even in the middle. Then look at your spindles.
Or just wore out shocks as well. Replace the shocks with a solid bar and test to see if it drives better. If it does your shocks are toast as well.
Look at the spindle bracket that is welded to the a-arms good. They are week there. Also these karts never rode good anyway. They do not like lots of lbs in stock form. Or the two that I had anyway. Both needed front end work though.
Does it look like micky mouse worked on the front end? are the tie rods clean with no wrench marks on the adjusting nuts? Are the tie rods bent?
Double and tripple check to make sure these work for your model. I just did a quick look....
http://cgi.ebay.com/Go-Kart-Cart-Ye.../190507287961?pt=Go_Karts&hash=item2c5b1e8599
http://cgi.ebay.com/Go-Kart-Cart-Ye.../200234359348?pt=Go_Karts&hash=item2e9ee5da34
And the bracket
http://cgi.ebay.com/Go-Kart-Cart-Ye.../390027250099?pt=Go_Karts&hash=item5acf6f89b3
bobby28
here are the pics with none siting in the cart
bobby28
more pics sorry if this is too much just tell me and i will delete them thx for trying to help me out
bighead
In pic 2 it looks like the tie rod is bent pulling the tire into the frame. Also looks for cracks around the rust marks on the spindle bracket. Take another pic looking at the front of the cart with wheels pointing strait so we can see what the wheels are doing.
My guess is the shocks are shot. And the tie rods are bent. And the welds are broke around the rusty spots on the spindle brackets.
The shocks are shot for you can see that the a-arms are dented from jumping the kart of to many lbs. Always looks for cracks when you see rust around welds.
bobby28
here is some more pics to see if you guys can help me out
Bluethunder3320
get waaaaayy stiffer shocks, and mod some beefy tie rods.
i bent a tie rod once, driving up a tree, but it helps me in my case because it was too long!
take measurements on the shocks and try to find motorcycle shocks, atv shocks, or just stiffer springs.
gokart14
Nebraska
yep evrythng seems fine just need stronger shocks :)
pic 3 someone is sitting in the kart shocks look fine whats with that?
