Fuel Efficient Mods?
karl
North east Ohio
There is alot of mods to increase power, but I wanted to make an engine more fuel Efficient. I have a 3hp briggs and a series 20 comet tc that will fit it. I wanted to make a small stand on scooter type of thing to get around on next to no gas. I was thinking of shaving the eyebrows, and porting the ports. I also was wondering if getting a thicker head gasket would help flow. Also what does a fireslot do? What mods can you do to make a engine more fuel Efficient?
r_chez_08
Should be in the shop...
Cornwall, UK
Thicker gasket helps flow but decreases compression. As it is you are shaving the eyebrows so if anything i would remove the head gasket (see russ's sticky)
Rob
r_chez_08
Cornwall, UK
Removing the headgasket would reduce flow since its a flathead.
I know, but as he is already shaving the eyebrows he is gaining flow and loosing compression, so if he was to put in a thicker gasket he would gain more flow but have even less compression, so that is why i suggested removing the gasket.
Rob
redsox985
PA
Leave it stock will give you the best fuel efficiency unless you further choke it out. Improving the motor's output will only consume more gas.
newrider3
Colorado
I really doubt that a 3hp Briggs uses enough gas in the first place that modifying it would have any positive effect.
j.concepcion54321
Rebuilding KTM, Need Kart
East Providence RI
my 5.5hp honda fills up with about 2 dollars of fuel with the gas at 3.99 per gallon here in RI.
its not tooo bad.
if you want fuel economy sell your engine and tc and buy an electric scooter, or an electric motor. thats green and im pretty sure u dont have to pay the electricity bill so its goin outta ur parents wallet :D
#28 FASTGRASS
Adelaide Hills, Australia
If your going to mod it for fuel I would just stick to a polish of the ports with 150 grit wet & dry (you dont want a mirror finish in the inlet side, a liitle rough here is preferable for what your after) and around the top side of the valve areas and inside the head and exhaust port to a mirror finish with 1500 / 1800 grit wet & dry (you could wet rub this?) and then go with liquid metal polish to finish the job.
In the ports rub out any really sharp and lumpy bits of metal that hinder / upset flow, but dont go any further.
Another suggestion which i tried and it helped was to make sure the carby/manifold/port lines up really well and the gasket dosent get in the way. As the others were saying up the comp ratio, that always helps, I probably would not worry about the loss flow too much..........:idea2: How about you angle mill the head and re-spotface the bolt holes square again, works wonders on a chev 350.... eg cut more material off the bore side e.g. 0.040" and tapering off to a 0.001" at the valve side? Anybody on here tried a rim flow valve in the inlet? great for flow but crap for smog.... (comments welcome on that one all, as I am not a B&S man, other issues?). Another thing which may help is a Phelom? chamber That is a carby spacer, play around a bit with the length and you will get a nice "hit" (on a 3.5HP???;)) of torque in the bottom end and mid range rev's....well it worked well for me on a motor, worth a try here too me thinks......torque will give you more "push" the theory being that then you dont then have to open the throttle more to get going and hence save an increase in fuel efficiency......
thoughts anyone?:popcorn:
Or do we just buy a Honda?:stir:
There are some "hyper miling" fuel econo sites out there too if you want to explore a bit......
