Subaru Robin Fuel Pump Help
Sail8870
Manco
I have a 6.5 Subaru robin with the original gas tank in use. I would like to use the floor mounted tank under the wheel, but I guess I would need a fuel pump in order to do this. Can anyone lead me in the right direction of a fuel pump that is compatible with my engine?
Thanks
I'd suggest you use this model of Walbro pulse fuel pump:
http://www.arcracing.com/servlet/the-65/Walbro-pulse-fuel-pump/Detail
http://www.arcracing.com/servlet/the-461/Blue-Fuel-Hose-Gas/Detail
http://www.affordablegokarts.com/mm5/merchant.mvc?Screen=CTGY&Store_Code=A&Category_Code=PFS
But buying/installing the pump/filter/lines is the easy part... the tricky part will be installing a pulse fitting in your engine that's needed to operate your pump.
First you should read this info about about installing pulse fittings: http://www.affordablegokarts.com/fuel-pump-setup.php
I drilled a hole in my carbs factory plastic, heat-insulator, and installed a 1/4' barbed-fitting, to slide/clamp a 1/4" hose on, that supplies the pulse-signal to my karts fuel pump:
Mine works fine like this.
More info/pics in my kart thread here:--> http://www.diygokarts.com/vb/showthread.php?t=3664
I heard this place sells speed parts for Subaru industrial engines like yours:-->http://www.exotictoybuilder.com/index2.html
You might try emailing them and ask if you can buy a fuel pump and lines/filter from them. And then also ask if they sell any other speed parts and then just casually ask what is the best method to install a pulse fitting in your model engine. Cause I dont know anything about Subie's...
Sail8870
Manco
And with regards to the fuel pump, I can tap the pulse fitting almost anywhere on the engine and it should work well? I think i am going to drill and tap a hole into the valve cover, because that seems to be one of the easier ways to do it.
Hey looks like you gotta cool place to ride :thumbsup:
Yeah, the valve covers's probably a good choice, pull it off and see if there's a good spot that wont cause any problems. If your unsure about anything post some pics/video and we'll try to help.
tireboy
I heard this place sells speed parts for Subaru parts industrial engines like yours:-->http://www.exotictoybuilder.com/index2.html
wow thanks for posting, I might do this as well when I got my money. you're pretty amazing
