engine shaft mishap, my options?
Bluethunder3320
ok so i think i did have a thread on ways to turn the 1" shaft to 3/4"
i ran the engine (tecumseh HM80 flathead) and angle grinded the shaft.
heres what i came up with..... :mad2:
so tomorrow i might be able to get a quote from a machine shop.
t-man thought of a good idea: i get it machined to 5/8", then use a sleeve to bring it back to 3/4" because thats what i want.
also, i cant use a torque converter unless i get it drilled and tapped right?
but i can use a cent. clutch with a set screw.
just ordered POR15 for the engine and shrouds and tank.
The Mechtician
Gargamel Jr.
Surrey, BC, Canada
LOL you're doing it wrong! Wowsers in me trousers, that's horrible! I know you're still young & have a lot to learn, but when you make decisions like this it's setting yourself up for failure, and you should have known that from the start. I hope you learned your lesson! Do it right next time and take it to a machine shop.
As for a fix, if it were mine I'd build the surface back up with weld and machine it down to 3/4. DO NOT USE FLUXCORE for buildup! It's doable with fluxcore, but not without excellent technique (to prevent slag inclusions) and not without vigorous cleaning after every pass.
I'm generally against using speedi-sleeves, especially on moving vehicles that will be carrying my a$$ at high rates of speed. If you do use a sleeve, thoroughly coat the inside with red loctite, and loctite the key in place as well. You could also purchase a 5/8" bore clutch, northern tool sells them and they're not any more expensive than a 3/4" bore clutch. Get the machine shop to drill & tap the end of the crank for you, it shouldn't cost you much more since it'll already be in the lathe.
Bluethunder3320
alright, and i know i would need a bolt in the crank if i decide to use a TC.
my worry with the TC is that this is an 8hp engine, and most TC's for 3/4" are rated to 7hp. is that close enough? what would happen by over powering a TC?
i am debating if i should just start welding on it. i probably have enough wire, but im not sure if thats the best way. i guess ill just talk to the guy at the precision shop first.
BTW, the guy i know does some great work, so i know if he is going to do it he will make it ABSOLUTELY perfect. here are some sprockets he did a little over a year ago for my first project.
just look at the perfection here. remember these are KIDS BIKE SPROCKETS one welded to a chainsaw clutch, and the other ontop of another sprocket!
Cam
Nz Petrolhead
Whangarei, New Zealand
Didn't we discuss how welding the shaft would warp it last time?
I Suggest, get it machined down to a usable surface, which might be hard because you have heated it up and it may be work hardened now, then i would broach a keyway and then ake a shim with grub screws, unless there is enough meat on it to have it machined to your liking.
r_chez_08
Should be in the shop...
Cornwall, UK
If heating distorts it, then clock it up to see how far it is out, then right it, with heat + hammer.
Rob
Bluethunder3320
well if i welded it enough then it wouldnt matter if it warped a bit, because it would be machined smaller, i thought, unless it doesnt warp where it goes into the engine.
i think it is just a tad lop sided.
another possible solution:
the guy i got this engine from had alot of blown up motors. tecumseh's to be specific. i could ask him to look through some and try to find a 7-10 HP tecumseh and take the crank out. BUT i would still have to get it machined or at least drilled and tapped because the snowblower's had no need for a bolt in the crank, they almost all had pulleys with set screws.
sexyvicta
have you considered calling your local mower shop to see if they have any cranks in stock?
i buy victa crankshafts for like 40 bucks brand new
Bluethunder3320
they dont stock parts like a crankshaft. most of their work is replacing engines, not working on them, because its $60 an hour on labor, and a brand new engine would be cheaper in most cases.
also tecumseh went out of business 2 years ago (or was it 3?) so theres really nothing for under $150 right now......
most likely they will just let me have the crankshaft or a pretty low price. its not like they can do much with a blown up motor w/o carb, starter, exhaust, head, connecting rod, and coil..... the thing i am hoping is that they have a parts motor with a identical shaft.
Bluethunder3320
Send it over here, ill machine it up
woah, :cheers2: that would be awesome, but first im just going to see if i can get a correct crankshaft out of a blown up motor.
im 99% sure im going to the lawn shop today so i will see if he has a crank.
if its 1", i may actually keep it 1" because most torque converters that are 3/4" are rated up to 7hp, i might be able to get by..... but just for the extra protection and life of the TC its a good idea for me to keep that shaft diameter.
some HM80's were 3/4" OD shaft-ed from factory, not very many i hear.
the jackshaft on my Baja warrior will bolt right onto this engine, and this engine will bolt right into the mounts, soo........... if it was 3/4" shafted all i would have to do is swap and use my regular cent. clutch for now. (i actually have 2 plus one that needs a spring)
cam, i will update you what happens today. thanks!
Cam
Nz Petrolhead
Yeah no worries, im sure we can work something out
Can i ask a quick question? Do any of you know the pitch of the output chain on a comet TC20?
Bluethunder3320
ok so i was really happy today and now im pissed!!!!
i went to the lawn shop and got a parts motor. unfortunately he had no more H80's or HM80's so i took a 9hp.
THE SHAFT DOESNT FIT THROUGH MY BLOCK..................
this motor is extremely low hours, but its blown up because the owner never put oil in it. its just dusty because it has been sitting so long.
so i have ABSOLUTELY no idea where to go. the 9hp tecumseh has a 3/4" OD shaft DRILLED AND TAPPED!!!!!! perfect!!!!
but, no rod, no cam, and no side cover.
Bluethunder3320
ugh............ im going, fix the 9hp, no, get the 8hp crank fixed, wait no, fix the H60, wait no i need too many parts, UGH.
Oh well, look at the bright side, blue... your building up a nice collection of tec H80 parts there. Some day you'll probably stumble across a bargain on all the parts you need to get-em both running :thumbsup:
Bluethunder3320
btw- anderkart, i have 3.
this one is missing a ton of parts but runs.
and yeah, thats a briggs carb and home made manifold.
