thermos?
I thought it sounded good and looked pretty dang cool. If its stainless steel the finish should hold up good too. Although I'm a bit concerned the hot exhaust might end up melting that fender...
kendelrk
redneck engineer
westland michigan
i was thinking so, so i thought maybe like a extender and then the thermos, and the dude said it was only like 12 bucks and it sounded great, and then thinking again, what if we made like a nice adapter for the end of the thermos where you could put like another silencer for a stright pipe so when your out and can be loud you take it out but if your in the neighbor hood you put it in so its quiter
kendelrk
redneck engineer
westland michigan
Yeah you pull the adaptor and put the cap on. I'll have to try to fab some of this up. And like if you were to say wants it to match a blue kart you can paint it with BBQ paint because it dosent burn off
devino246
Official DIYGK Chem Nerd
Lynchburg, VA
If you really wanted to be creative, you could grind the threads off the cap & lighten it some, then fab a hinge so the cap is one of those little exhaust flappers.
Bluethunder3320
this is the exhaust i made. just a briggs muffler. it was free so thats a plus.
bbq paint is great.
Bluethunder3320
the thing is, water bottles are stainless and thin, so it would be hard to weld them and you'd need special wire if that (or a TIG)
devino246
Lynchburg, VA
stainless is still steel. You can wire weld stainless with regular wire, the weld will just rust. Those bottles arent that thin. They're alot thicker than the tank I used for my muffler.
Badot
The ones that Walmart sells here are fairly thin, but they have a rolled lip on the side the cap goes on that I'd think would weld up pretty easily.
devino246
Lynchburg, VA
but its going to be whole ley packed
:huh:
ive tried paint cans...... doesnt work well. just blows holes.
I think it was Kap'n, had used a rattle can for a muffler. He had to cut the hole slightly smaller and pressure fit it.
I may have to try this SS bottle thing, even though I've hardly done anything to my kart in months.
redsox985
PA
I would like to try welding a spray can with one of the MM140's at school and then using a bunch of tacks. I think they can do down to 24ga sheet metal.
