Need some advice.new to go carts
dmiller369
my girlfriends little sister bought a go kart with a 5 hp Briggs motor.
its in pretty crappy condition.I have road dirt bikes all my life so i plane on tuning it up for her. here is what i plan on doing. any other advice?
1) weld her tie rod back on
2) clean her carb.
3) 3/4 x 12 straight header
4) new performance air filter.
5) shave the eye brows.
6) New spark plug (what kind ???)
7) possibly change the sprockets
now my next question is what else should i do to gain a little more power. I was going to remove the gov. but i fear she would just blow up her kart.what is recc. for up grade in the 20 dollar range?
thanks alot i know im a newb, so be easy on me and help me out.
r_chez_08
Should be in the shop...
Cornwall, UK
looks good so far. if you have access to a mill or a lathe you could shave the head a bit, if not you could eliminate the head gasket, see the sticky.
Im guessing you have a flatty if you are shaving eyebrows?
Rob
dmiller369
flatty? i was planning on using my dremel.
what kind of dremel bit is best? and what kind of spark plug will be best after these modifications are done?
I'd probably just skip the eyebrow shave with the governor still all hooked up. That's something usually done to improve power at higher-rpm. I'm not sure if it would help anything @ 3600rpm or not.
dmiller369
what size of sprockets are best for the front and back? im looking for all around performance not just top end or bottom end?
We need to know how tall your back tires are?
And if you guys will only be riding on flat parking lots/streets, or more off-road/hill-climbing type situations? (or both?)
Posting some pictures of her kart would help us get a better Idea of several things including its weight, and really help us out in suggesting your best possible gear ratio too.
dmiller369
i plane on posting pictures soon. they live on a farm so it going to be driven in just grass. my g/f said that its hard to go fast cause it gets really bumpy. the current tire size is 12 inchs and they are very worn out. where to you suggest to get new tires and what size? there is no suspension.
Her kart might be geared fine now. We'd need to know how many teeth are on the clutch and axle sprocket now, before we could suggest any changes.
Besides being 12" tall, we'd also need to know the rims diameter and approximate width to recommend any replacement tires. Once we knew the rims dimensions, we might be able to find some suitable ATV-type tires that would soften the ride a bit.
When riding on grass, you might wanna just leave the stock muffler on to act as a spark arrestor.
Straight pipes can allow bits of glowing carbon/metal to fly out that can easily start fires...
