Quad Build.
HellSpawn
Wadena, Minnesota
Some progress for the night..
Got the rear hubs on, need to calculate some kind of gear ratio and find a sprocket. Stole the steering column from a 74 Bombadier snowmobile.
Those rear tires are just placeholders until I can find some with more meat!
But it steers and rolls so smoothly, I actually surprised myself with getting most of the steering geometry correct on the first try. Usually I end up sitting there for an hour putting everything together and taking it back apart until it steers the way I want it to.
sideways
Unfinished projects king.
Perth, Western Australia
Cool build mate, I'l be keeping an eye on this one! :thumbsup:
Nah, you'll see alot of the higher-end ATV's (ie a sportsman 500) have single front a-arms. But they are pretty beefy, which is something I still have yet to do is beef them up.
They have MacPherson Struts, much better than single A-arms, even then, they still handle like crap. No quad that I know of (minus Chinese ones, but some of those have some real scary **** for front suspension, others are very well designed) has single A-arms on the front.
I'd leave yours single A-arm, you need to sort out suspension geometries and bump steer before you bolt another arm on.
I'm building a quad too, doing it much slower than you though! I've got the engine from a Chinese quad (233cc twin cylinder, has reverse gear! :wai:) Even though the engine is chain drive I plan to make it shaft drive, so sick of dead chains and sprockets from all the mud. :mad2: Just designing it, collecting parts and making smaller bits for now.
If I was you, I'd stick a Briggs or something in it until you get a motorbike engine. :thumbsup:
Thanks
Hayden
HellSpawn
Wadena, Minnesota
Thanks
Hayden
I've actually been really tempted to just make some temporary mounts for my 18hp Briggs and toss that in there.
But uh, I still need to break all of the pieces down and finish welding it all and clean it up.
HellSpawn
Wadena, Minnesota
Not much of an update tonight, I redid the steering a bit to make it a tad easier to turn, and it actually steered a bit more smoothly than before. I tried test fitting my briggs in the thing, and the way it is, I need to take my custom header off and possibly modify the air filter assembly. no big deal.
HellSpawn
Wadena, Minnesota
Few days since I've updated this, I've kinda been stuck wondering what I will do for a driveline as I don't feel like shelling out cash for a 40 series (assuming I could find one) and my 1" I.D. Clutch is a bit worn out.
So! I started sniffing around some of my old snowmobile carcasses and discovered one that actually had a chaincase that went to a 1" O.D. shaft. I'm still contemplating if I want to keep the chaincase and use that gearing, or just build my own jackshaft with the driven and call it good.
But plans for a driver/clutch... I will be machining a sled clutch to fit the 1" shaft and swapping the weights out for the correct engagement.
HellSpawn
Wadena, Minnesota
I may need some opinions on gearing with this sled T.C. I essentially want to get around 35-40mph out of this thing with decent acceleration. But I don't know of any differences that using the sled TC will have.
HellSpawn
Wadena, Minnesota
Update!
Got this yamaha clutch fitted to the briggs!
What you see in the pictures is a actually a yoke shaft with a 1" I.D. with keyway that I turned down.
Also bored out the inside of the clutch to remove the taper. Sleeve is a press-fit. Shouldn't slip, ever.
Haven't fiddled with the engagement rpm yet, but currently it engages at about 2500, which isn't terrible, but its within the torque range and I certainly wont be test riding it like that.
I also ended up tearing off portion of the rear tail-section because I wanted it a bit longer and less of an angle.
Todo: driven clutch and jackshaft, and cut keyways in axle, and lastly brakes.. which won't be tough as the driven has a built in disc, however chances are is I will get one for the axle instead and use hydraulic instead.
pics!
HellSpawn
Wadena, Minnesota
Change of plans!
I'll probably be keeping the briggs with the sled clutch around so I can tweak the weights and spring in it and use it for another project, however, theres an off chance I may sell it once I get it in complete working order.. So if you're interested in a 1" clutch that can handle over 10k rpm and 40hp+ let me know :p
Anyhow, the bike is essentially the same thing as my Honda CM400T, however this is a Model C, which comes with electric start (no kickstart at all) and a tachometer.
This motor is rated at 43hp @ 8500, may end up being overkill for this project.. But I like having more power than I know what to do with. :)
HellSpawn
Wadena, Minnesota
How it sits as of right now... I ended up using a good portion of the existing bike frame to make things easier, but I still expect it to need LOTS of bracing for this heavy and powerful of a motor.
Somebody come help me wire this **** thing o.o They made it so complicated.
j.concepcion54321
Rebuilding KTM, Need Kart
East Providence RI
hey did you ever get that clutch working on tha briggs? im thinking of getting that engine and am kinda stumped on clutch solutions as i have like 50 bucks in my pocket.
