How to make a 5.5 honda clone engine faster
j.concepcion54321
Rebuilding KTM, Need Kart
East Providence RI
Hey guys i currently have a 5.5 honda clone engine on my concession style go kart. im running it without the body so that there is a little less stress from weight on the engine. it has a gearbox with internal wet clutch that then drives a toothed belt to the live axle. What i wanted to know was how i could get more performance out of my engine? I know that theres removing the governor but isnt that a bit risky?? i also heard that by changing the exhaust itll work better, and by removing the airfilter cover also. I can post some pics of my engine later on if need be.
Thanks,
Josh
karl
North east Ohio
Use the search function on the forum and type in something like performance mods and other keywords relating with the topic
devino246
Official DIYGK Chem Nerd
Lynchburg, VA
Removing the air filter cover wont do anything. Replacing the stock filter with a high flow will, but you'll need to rejet the carb.
Bluethunder3320
It almost always will, unless you live on top of Mount Everest where theres hardly any air anyway.
yeah i have not tried to run a stock carbed clone with a upgraded filter, but i put a straight pipe on one of my clones without rejetting and it works fine.
Bluethunder3320
i have ran one with no filter at all though because the choke broke off. i forgot about that one. it ran fine just as normal. im not meaning to argue with you, just sayin that if the OP gets a new filter, of course try it out first then rejet if needed.
karl
North east Ohio
Dosent the carb have a mixture adjustment screw? If you run a straight pipe and a high flow air cleaner back the screw out in tiny increments until it runs good.
karl
North east Ohio
Oh ok I never mess with my clone, I still have the stock air cleaner and muffler on it. I mess with briggs and strattons usually
devino246
Lynchburg, VA
Even the carb on my truck has fixed jets. The only mixture adjustment is for idle.
karl
North east Ohio
That is another reason I like briggs and stratton engines. Almost every engine made by briggs has a mix mixture adjustment screw.
slideways
Yea if they were made years ago. You won't find a mixture screw on a Briggs main jet nowadays either. Its not the manufacturers choice.. its the EPA.
Unreal.
Anyhow, to actually answer your question- geared correctly, removing the governor allows a higher engine RPM, which is in direct relation to roadspeed. So yes- As long as you aren't geared too high.
