planning on building a shifter kart.
chuck
im thinking of building one but i need to learn more on prices. i want to put a rm125 motor with bumped up comp,bigger better carb,running alky,vf3 reeds,ported,custom pipe in a shifter kart. but i need to find a way to get a shifter kart roller for like $300. can i do that?
It'd probably cost at least $1000 to buy a true 125 shifter kart in decent shape. (and that's w/o engine)
Check out this thread:--> http://www.diygokarts.com/vb/showthread.php?t=4742
That dude started out with an older Sprint kart just like my Dino kart below. He just added all the Shifter-kart type accessories like front brakes and clutch/shift-levers.
Besides those shifter-accessories and a 50mm. diameter axle , Shifter and Sprint karts are the same dam thing.
You should start checking your craigslist for a deal !!! Check the ads often and be ready to move fast when you find a deal. The true bargains usually sell within an hour or 2 of the ad being posted...
I bought this mid-1990's Dino Sprint kart for $100 on craigslist.
It looked terrible when I got it, but it just needed an engine, paint job, tires and a new seat.
I also bought this 2002 Invader for $300 on craigslist.
It looked just like you see here in this pic below, but w/o engine:
chuck
so how fast could i expect to go with a 06 rm125 motor set up like mentioned above in a sprint kart chassis?
redsox985
PA
Do you plan on racing competitively? Are those rental kart frames any good? I've noticed them on my CL a lot cheaper than the racing karts. Could those be a good alternative if you don't wish to spend that much on a frame alone.
Rentals are usually pretty heavy, unless they're actual race karts they'd probably never handle and turn as well as the real thing. Post a link to one of those rental kart ads if they have decent pics. Maybe they're real racekarts but just have heavy-duty bumpers and side-rails.
I found bargains on all my used race karts. Lots of racers can't afford to race any more so there's lots of good deals to be had out there.
chuck
i think a rental kart would be fine without all the extra bumpers and such
I feel that if you took off all of the "child proofing" and extra strengthening, you could have a decent race frame.
The thing is most guys here dont realise about real race karts is while making a high speed turn, the frames are designed to flex just a certain amount to unload weight off the inside-rear tire, and transfer that weight to the opposite corners front tire.
Unloading weight off the inside-rear tire allows the live axle to act more like an open-axle to turn better. Transferring that weight to the opposite front corner allows that front tire to get a much-much better grip.
If the frame is too stiff or flexes too much, the kart just cant transfer weight correctly to turn and hook well in the corners. Besides the correct amount of frame-flex, race karts made in the last 10 or 20 years also have adjustable caster, camber and adjustable ride height at all 4-corners. These adjustments all change how-much and how fast that that weight is transferred.
Modern racekarts hook up in the corners so well they can actually develop more G-force than a 3 million dollar Formula-1 race car!
What kind of frames lie under those karts with mini racecar bodies on them?]
Do you mean like these?
(most of these are just a cheapo fun kart chassis with open axles)
Or did you mean like my racekart with a body pictured below?
Hey that actually looks like pretty good deal :thumbsup:
Its a pretty old design so it wouldnt turn and handle as well as newer racekarts, but then again it doesn't cost $2000 (w/o-engine/tires-wheels/seat and body) like a new one either.
redsox985
PA
I was thinking something more like the one below. They surface a few times a month on my CL and I was wondering if they could be of use to the OP because he didn't specify whether or not he wished to race where frames are regulated or just build a street kart where that older $300 frame would be great.
chuck
i just want something like a shifter kart frame or something like the dino in anderkarts post.
Those rental chassis would be fun to ride but they could never handle and turn as well as a race kart.
With all the brutal power of his RM125 and trying to make corners at 60mph... having a kart that actually goes in the direction your trying to steer it would be handy at the track or even just playing around on parking lots and stuff.
If you posted the nearest big town near you, somebody here might just help you search for a local bargain :thumbsup:
chuck
i like the first one. last question. if i put my motor in there and upgraded braking would i be able to race in any classes?
That first ad is is a very cool vintage racekart. Margay was the most popular brand of racekart back in the 1970's when that one was probably made. It's a collectible kart and its value is probably increasing.
But I'd still suggest you contact the sellers of those other kart ads i posted and try to get pics/more info about what brand/age they are. One of those others might end up being a MUCH better candidate to race at a track.
Some kart tracks dont allow older vintage karts like that 70's Margay to compete in the Shifter kart class. Shifters are the top/fastest race class and many tracks have very strict tech rules that may not allow karts built before the year 2000 to compete in any class.
Many kart tracks also require you to race at least 1 season in one of the lower/slower kart classes to prove your driving skills before graduating up to the 125cc-shifter class.
The tech rules vary from track to track so you would need to get in touch with your tracks tech inspector and ask. Or, some tracks have web sites with all their rules/tech-info posted on-line.
So we'd kinda need to figure out what track you would race at to get started researching here.
These 2 links have several kart race tracks listed in W-Virgina and Kentucky.
Which one of these tracks would you probably wanna race at:
http://www.na-motorsports.com/Tracks/WV/index.html#OutdoorKartTracks
http://www.na-motorsports.com/Tracks/KY/index.html#OutdoorKartTracks
