Tecumseh HM90 running rich/backfires/surges
ahickman
We bought a kart this weekend with a Techumseh 9.0, model number H90. The engine and kart are in decent condition and is running. However, after a half day of riding, the engine started backfiring when letting off the pedal and then starts to surge/sputter randomly. The PO said the kart sat for about 3 years so he replaced the carb and said the governor linkage needed some tweeking. I know recognize that the linkage is a homebrew (odd springs/pieces) and is most likely not original.
My first question is regarding the running rich condition. When shut off, I can see fuel leaking from the carb/filter. I also see black soot on the muffler. On the carb I don't see any mixture adjustments. Are there screws on this model?
What is a good rule of thumb for adjusting the governor and throttle linkage?
Thanks,
Aaron
I'm guessing your fuel tank had some dirt/rust inside that broke loose and flowed into your carb, and then got stuck in your needle and seat valve keeping it from shutting off the fuel flow.
I'd take that new carb apart, check for dirt and clean it. Then check and clean the fuel tank and also flush the fuel line out.
Does it have any type of fuel filter or strainer-screen to help keep dirt out of the carb?
If so, clean the screen or replace the filter too.
If not, installing an in-line fuel filter would probably be a good Idea to help keep this from happening again.
Bluethunder3320
+1 ^^^^
are you sure its the proper carb, and there is a intake gasket???
leads me to believe what toystory says, since it just started to happen.
ahickman
Taking the carb off tonight and giving it a once over. It has a float. Any tricks to float adjustment?
As long as you dont bend that float arm on that new carb, your float-level should still be set from the factory. Just look for dirt and take it apart carefully so you dont damage the old gaskets/seals and have buy replacements.
Make sure you poke/spray out the main jet too. You'll find it screwed into a tube that's hanging down into the center of the float bowl. The main jet unscrews from that tube.
Also: scratch a line across your float bowl and carb body, so you can know where to install the bowl back in the same exact orientation/position.
