I have a Honda 5 HP horizontal that I want to put on a kart body. After removing the pump plates, I found that it was not keyed, but was threaded. Kind of a bummer. What options as far as clutches do I have? I was hoping to use a simple centrifugal clutch ($50) with keyed shaft.
Aaron
Pics would really help us to help you, but:
If your current output shaft is long enough, and also a large enough diameter, you could probably machine it down to a standard 3/4" diameter, and broach/cut in a keyway, so you could install a standard 3/4" bore centrifugal clutch and key.
Then you wouldnt necessarily have to drill and tap the end of the crank if you bought a clutch that was equipped with set-screws to hold the clutch on.
But if you have to pay a machine shop to have this done, It might end up costing less to simply replace the crank or maybe even buy a different engine.
How long is your engines output shaft?
And what diameter is it?
Does it taper down from large to smaller at the end?
