Help me decide which clutch
kc9ljo
For starters I have never tinkered with go karts. Just about everything else with an engine but this is my firtst go kart. I picked up a Yerf dog 3203. There is no engine, but that's ok I want to go with a bit more power than the original anyway. I am planning on putting a 12.5 hp Briggs on it. I have all the drive parts, except the driver clutch. So I was looking at the prices, and I find that prices are pretty close to the same for a replacement driver clutch that is like the original, or a centrifugal clutch. Just wondering what ya'll think would be the best way to go? Also where are the best places (online) to buy such parts?
Thanks!
Bluethunder3320
He is right.
Youll have to upgrade the whole TC.
A torque converter is always better, but just more expensive. You can get a 1 in bore cent clutch for about 110-120
Thanks!
If your going to ride off-road/hill climb you'll definitely want a 1" bore / complete 40-series torque converter system for that engine and heavy kart.
But If you will only be riding on mostly all flat hard surfaces, you could use the 1" bore Noram 1600 series, 10-tooth #40/41 centrifugal clutch model found at this link: click here--> http://www.kartpartsstore.net/servlet/the-375/The-NORAM-1600-Series/Detail
(you would just need to have the kart properly geared, which would probably include using a jackshaft setup)
Send this DIY member a P/M (private mesage):http://www.diygokarts.com/vb/member.php?u=5853
Blazkowiez is a very cool knowledgeable guy and he will help you a bunch. Tell him you'll be installing a 12.5hp briggs engine on your Yerf dog 3203, and he will send you pics and info regarding some simple chassis/rear suspension bracing upgrades you will need to do so your kart can withstand the extra weight and power of that engine.
Your sorta right, I agree a torque converter would probably be the best choice for the OP's kart and situation here, but you said always and sometimes a centrifugal or disk type clutch is a better choice for other types of karts.
An oval or road-racing type kart would make faster lap times on most racetracks with a centrifugal or disk type clutch than a torque converter system.
So a torque converter system is not "always better".
And some of those racing clutches cost over $400, so T/C's are not always "more expensive" either.
If you use an engine that big, you wont be able to use any part of that torque converter.
:iagree:
The OP would need to get a complete 40-series T/C system, including driver, driven, belt and a conventional frame mounted jackshaft, and not even re-use the 30-series/tav-2 mounting plate-jackshaft.
