Single A-arm Suspension
qtband
St. Louis, MO
I'm building my first Kart and would like to know if I can use a single a-arm on the front suspension. It seems easy enough, but I can't find much information. Mostly I find upper and lower A-arms being used.
Ken
cpt.skier
Calgary Alberta
http://www.tres-angle.com/Merchant2/merchant.mv?Screen=CTGY&Store_Code=GFOM&Category_Code=ORSS
http://www.eziplans.com/Product.aspx?ProductID=18
These both have a single a-arm design. Most people use a double a-arm design because they are planning on building a cart/buggy for a larger engine. Single a-arm are weaker then a double a-arm.
Quick question. How large is the kart you are planning on building? Bighead (one of the numerous senior members on this site) has a very simple design that can be used for a kart that is small/medium sized. If the you are planning on building something small it could be a good option.
Heres the link.
http://www.diygokarts.com/vb/showthread.php?t=10801
theo
Heres the link.
Can you explain how single a arm suspension is weaker??
cpt.skier
Calgary Alberta
Maybe thats just my understanding of it. Would there be any logical reason that the strength matches or exceeds that of double a-arms? I guess it depends upon how you build it. Im going to post two documents. The first is a simple one is quite simple, the second is reinforced (please excuse my shabby workmanship on sketchup. these were down in five minutes).
  • simple a-arm.pdf
  • reinforced a-arm.pdf
Rustydog2010
NZ Nutta :|
New Zealand
I think Theo is meaning why A arm suspension is weaker than AA arm suspension. I personally think it is, as the amount of contact points is double (Or whatever), this will allow force to be distributed though the different contact points at lower quantities.
I think the main advantage of AA arm suspension is the way that it prevents the wheels camber.
Jeremy.
qtband
St. Louis, MO
My kart will be similar to the Tarantula, or Dirt Devil. Probably considered a medium size. I'a using 1.25 square tubing for the base frame, one inch for the non-essential stuff. I'll tell you, those J arms look interesting. Couldn't I just fabricate those? Looks to be simple to do. Any thoughts?
Ken
theo
Dual a arms are the way to go, much better then the single, but the single is just as strong as the dual a arms.
devino246
Official DIYGK Chem Nerd
Lynchburg, VA
Single a-arm are much easier to set up. If it means anything, my '79 truck essentially has single a-arm front suspension.
devino246
Lynchburg, VA
Actually, most cars only have a lower arm and a strut.....
McPherson struts are a whole other thing. Older Ford trucks had patented "I-beam" front suspension; essentially very long a-arms that criss-cross. Although the camber does change during travel, the length of the arms makes it minimal.
qtband
St. Louis, MO
I found an ATV frame, complete, on Craigslist for $50. I'm going to use the suspension, brakes, etc. This will save me a lot of fabrication.
