This looks sexy!! 335cc Rotax engine
j.concepcion54321
Rebuilding KTM, Need Kart
East Providence RI
for the price is it a good deal?? how much work do you think would be needed to put into this to get it working? it looks like a sled engine. id love to make a scorpion style kart out of this or an offroad kart
Put it on a kart! But you really would need to find the matching CVT parts, or you're looking at a trip to a machine shop to make standard driveline parts fit.
j.concepcion54321
East Providence RI
i cant just throw a centrifugal clutch on it?
11hp honda clones are rated at around 337cc so would a honda clone carb work on this without any problems??
karl
North east Ohio
A 2 stroke revs higher so a centrifugal clutch won't last long. Also there ment to handle 10hp. For a carb go on ebay and find a used carb for cheap THATS IS FOR THAT MOTOR
Likely not. Sled engines tend to have odd/tapered output shafts.
It's not a "rating", it's the engine's displacement- which for simplicity's sake is the size of the cylinder(s). Displacement has no real correlation to horsepower or torque, especially not when comparing dissimilar engines. There's a lot more power than displacement.
Here's a good example or two-
My Honda GX340 (337cc or whatever it is) =11HP
My Yamaha XV250 Vtwin (250cc, 4stroke) =21HP
A Honda CR125 (125cc 2stroke) =30+HP
See?
j.concepcion54321
East Providence RI
I understand. But my question Is that I wanted to use a different carb so that I didn't have to pay aton of cash for the original carb. I was thinking of just making an exhaust . Would this work is what I want to know? And if not what could work? A Briggs or clone carb rated for higher???
What is this engine worth as it sits as of now? Is itwort the money?
Cruise the 'net. There HAS to be a forum for enthusiasts of Rotaxes, or older fancooled sleds. They likely upgrade the carbs for better performance.
redsox985
PA
This is a load of crap. The cent. clutches love higher RPM because they are fully engaged and don't slip as easily. There are many, high quality clutches meant to take well over 10HP. The cheap Max-Torques etc can't, but a Star or whatever, I'm not familiar with brands, can take well over 10HP. You do not necessarily need a carb designed specifically for that engine. It may be hard to find one because it could be quite old and rare, thus expensive. If a Mikuni will bolt on with minimal or no mods, why not? Heck, people do it often to HF 6.5s, why not a sled engine?
j.concepcion54321
East Providence RI
ok thanks toystory. still waiting for the reply from the seller. i really want this engine now. :)
how hard is it to get a cent. clutch for this??
how hard is it to get a cvt, or torque a verter to run with this??
Thanks
The Mechtician
Gargamel Jr.
Surrey, BC, Canada
I'd buy it for $30, but it looks old, I'm gonna guess 1970's vintage. Any decent sized carb will work, look on ebay for a carb from a 250cc dirtbike, or get a chinese mikuni clone from your local chinese garbage bike importer. The exhaust will be more difficult, best results (ie; most power) requires an expansion chamber, but good luck finding one for that particular engine. Look for an old expansion chamber on eBay, if you can't find one I suppose you could run a Russ muffler (the glass-packed VW exhaust tip) for a while until you get your hands on a tuned pipe.
Being a two-cycle, I believe it will perform better with a purpose-designed exhaust. But this isn't my area. I still think your bigger problem is the output shaft design.
I only spent a couple minutes google searching the Rotax 335 at these search links below:
http://www.google.com/images?q=335c...=UTF-8&source=og&sa=N&tab=wi&biw=1021&bih=649
http://www.google.com/search?q=335c...10&um=1&biw=1021&bih=649&ie=UTF-8&sa=N&tab=iw
I learned the OP's C/L find is most likely an 18hp. 1970 model, and had a 3/4" PTO:
http://www.vintagesnowmobile.com/cgi-bin/yabb2/YaBB.pl?num=1230105182
I would fully exspect that C/L engine to at-least be needing crank seals.
I feel that coupled with also needing a carb, air cleaner, chamber and clutch,
would take it from a low cost kart engine prospect to an exspencive prodject.
The pics below were all claimed to be 335 Rotax:
I cant see that the PTO Tappers, or has a keyway in any of them, so I have no idea what means
they used to lock the Driver to the PTO besides the outer retaining nut. That PTO must just have
a very slight taper.
______________________________
_______________________________
________________________________
I think the heavly tapered left side is flywheel, and PTO is on the right side of this crank pic below:
(edit: I held a pair of caliperes up to my computers screen and the end of the PTO did seem to slightly taper down...
