what size engine
jk95ht
central coast, nsw, australia
if i do turn my project into a go kart once i get home, what sized engine will i need to push about 90kg (my weight+karts weight) i culd easily and cheapily use a 49cc engine, but i dont think that will be enough.......
Russ2251
AZUSA:Powered by LAWN-BOY
Anything under 90cc's is a waste of time/money/effort. My opinion.
In my experience, I would not go less than 125cc's.
Currently I run 141cc (single) 1 wheel drive and 242cc (twin) live axle.
jk95ht
but what engines have that power though?
what price would i be lookin at for a second hand motor, or would a lawn mower engine power it?
r_chez_08
Should be in the shop...
Cornwall, UK
If you wanted to use a lawnmower engine it would involve a lot of work, because they have vertical shafts and karts use horizontal shafts.
You could also look on craigslist for any honda, briggs, techumseh or clone over 5hp.
Rob
sideways
Unfinished projects king.
Perth, Western Australia
Seeing as you're an Aussie, I'd suggest a Victa mower engine. You can usually get them from the tip for free. Do you want a centrifugal clutch?
We don't have harbor freight over here, I've never seen a 6.5HP clone for less than $300 so those aren't really an option
jk95ht
so if i want to make a decent gokart i need around a 6?......
and have any of you guys got links for plans etc for go karts like that?
if i make one it wont be as good as you guys, i just wanna make one so i can have a bit of fun in.......
Bluethunder3320
check out the plans on this website.
i might make plans sometime for the go kart in my avatar pic above^^ but i bought that frame for $50 with extras on craigslist and extended it, modified it, converted to a keyed axle and actual bearings, and some other stuff.
Bluethunder3320
And i just saw. Youre in AUS so the harbor freight clones are more like $300 there instead of $100. Do you have a junk yard near you that has any tiller engines, leaf blower engines, 2 stroke lawn mowers, reel mower engines, etc?
jk95ht
no not rly..... pocket rocket engines r the cheapest here but theyre only 49cc's........ everything else is fairly expensive...... i wanna try doin the cheapest go kart on the forums lol
Gillgamesh64
Griffith NSW Austraila
Yeah why not go for the victa two stroke and make a bracket to hold the engine so the shaft is horizontal, they are 125cc and 160cc Just look for an old victa mower that still goes, if you wanted new rings are about ten bucks!
jk95ht
this is a factory made off road go kart, take note of the engine size...... and it can take upto 100kg, the link for this particular kart is below, does this mean i could use a 49cc engine? cuz i can get a pod+throttle body for a 49cc for about $15 and a brand new 49cc engine for $40..... also that link ill check out when im home, im currently in my 2nd last class of the day then 3 weeks of holidays :p
Product Description
Engine: 49cc, single cylinder, force air-cooled, 2-stroke
Compress ratio: 8. 0: 1
Rated power and rotate speed: 1. 45kw/5500(r/min)
Max torque and rotate speed: 2. 4N. M/5000(r/min)
Fuel tank capacity: 2L
Driving mode: Chain
Starting system: Electric/pull start/remote-control
Steering angel(degree): 30
Tire(front/rear): 4. 10-6/13x5-6
Brake system: Disc brake
Mini ground clearance: 170mm
Dimension(LxWxH): 1500x800x885mm
Distance(front/rear wheel): 800/700mm
Distance(alex): 1060mm
Max speed: 30km/h
Max loaded: 100kg
Carton size: 600x1000x1520mm
G. W. /N. W: 80/65kg
Quantity: 20Ft/21pcs, 40Ft/45pcs, 40HQ/60pcs
Available color: Silver, red, yellow, blue, green, black
http://www.tradekey.com/selloffer_view/id/546796.htm
r_chez_08
Cornwall, UK
That 49cc is about 2hp @ 5500 rpm. Not that amazing considering an ungoverned clone could be 6hp @ 5000 rpm.
I dont know how the chineese expect that to move, considering 49cc is meant for a small bike!
I would see if you could find a small briggs, clone or victa on ebay, of atleast 120cc
Rob
jk95ht
Rob
force air-cooled, is that normal or is that like a fan on the intake pipe?
what im trying to say is, i have a 49cc engine on a pocket rocket, and i culd use that to power a go kart if i wanted to......
and it wont cost me a cent, and then if i feel like it i can upgrade later on..........
I believe "force-air cooled" is Chinese for fan cooled. No Voodoo, just a fan like every other.
Says max speed is 30 km/h which equates to about 18.75 MPH. LIGHTNING!!!
You seem pretty hellbent on using your 50cc engine. Okay- go for it. Build very small and lightweight, or the only speed you'll get is downhill...
EDIT Specs say 45Kw- WRONG!!! I wonder how many it really is?
jk95ht
1.45kw........ bit of a spacing but yer.......
culd always get a big bore kit off ebay for $70, giv it some power lol
