Clutch to torque converter
pek210
Oil City PA
I am putting a torque converter on my kids kart in place of a clutch. The bolt they sent for driven pulley on the crank is the wrong thread, can anyone tell me what bolt I need, its a 6hp tecumseh OHH60.
Bolt was #8 metric fine thread.
Then your engine must have been intended to be exported/sold in a country that uses the metric system, not the USA.
Or that metric bolt you used just happened to seem like a good fit, but its not the correct one.
Or someone re-tapped or cross-threaded the wrong bolt in there at some point.
You'll find this bolt's specifications for 6hp Tecumseh OHH60 / USA-version here at these 2 links:
http://www.shakyparts.com/ohh60_71216e_6_hp_tecumseh_powersport_engine.html
http://www.smallenginesuppliers.com/html/engine-specs/tecumseh/ohh50-55-60.html
If you searched the Internet long enough you could probably find the same specifications for the Tecumseh engines that were intended to be sold in countries that use the metric system. Typically, only those engines intended to be exported would have came with they're PTO tapped to metric threads from the factory.
You never bothered to fill out your profile so we could tell what part of the world you live in, but yet another possibility here is that your engine was sold here in the USA, but it was actually an export model that was intended to be sold in another country...
Bluethunder3320
well, he said the bolt was #8, he never said what bolt, the one with the TC or engine.
so problem solved?
Yeah who knows, he said: "The bolt they sent for driven pulley on the crank".
That sounded like he meant the bolt that holds the T/C Driver onto the pto me.
pek210
Oil City PA
The bolt was for pto.The old bolt that held the clutch on was hollow and had a grease fitting on the end. The motor was the origianl motor on a murry kart. May have been tapped by someone but was not cross threaded.
