Should I get a TAV?
dave1701
Good for 100,000 Miles
MICHIGAN
I am looking at this TAV on ebay and wondering if anyone has ever used a TAV with a one wheel drive? I think it would work, but space might be an issue. I have a 5hp tecumseh. Anyone have pictures of your TAV so I can look and see if it will work for me?
dave1701
MICHIGAN
Pictures:
Blazkowiez
Kart Aficionado
Houston, Texas
While it is possible its not the best idea to use a Torque Converter on one wheel drive, it transfers torque in a excellent manner, but if you do manage to mount the item without live axle it would be a terrible purchase. I can explain further later when I have more time if you need.
karl
North east Ohio
It would be better to work on putting a live axle on it first then get a tc later.You wont get any traction with one tire and a tc and also setting it up would be a hassle.
Badot
Running on one tire does reduce the drive traction, however my primary concern would be torque steering. If the left is pulling forward and the right isn't, it'll want to go in circles and constantly pull sideways on the front wheels. More torque (as from a cvt) makes this effect worse.
I'd talk to someone with more experience with CVTs than myself though.
I'm gonna disagree with this- I don't think the effect would be any more (or less) noticeable with a CVT.
Dave, weren't you planning on a live axle conversion anyhow? Let this be your motivation (pardon the pun).
redsox985
PA
It would require you to move the motor as the TC will never fit between the motor's current position and the tire.
dave1701
MICHIGAN
Dang it! My kart is such a pain. Converting to to a live axle will take a ton of money, a ton of effort and I might not be smart enough to even do it. How cheaply do you think I can do it?
dave1701
MICHIGAN
yea, I am going to convert to a live axle and this is a good incentive. I was looking at these TAV2s on ebay going for like $100 bucks. Can I use one of those off road with a gear ratio of 6:1?
