vertical to horazontil
B man
Tecumseh FTW!
Oliver springs,Tn
ok so i know the obvious reasons why u can stand it up but what if u just turned it on its side?(and i know u have to move the carb and etc.)
jrmints1415
Naperville Illinois
the oil will not be lubricating the cam, crank, etc. it is actually very easy to convert these engines if you know what you are doing. you need to make an "oil slinger" that is attached to the crank that scoops the oil up and flings it around. a small thin piece of scrap metal should do the trick. Then you will have to turn the carb around, and redirect your intake and your done. I dont really know what the difference is exactly but it still wont work just flipping it on its side.
EDIT: i thought about it more and it wouldn't work. Do you know how an engine works??? a spark is made to push the valve attached to the crank at around 3600 RPM. The reason it would not wor is that you wouuld not get proper gas flow to create the spark, but it will work if you stand it up and modify it. Why would you want to turn it on it's side anyways?
sideways
Unfinished projects king.
Perth, Western Australia
Because, on your average Briggs mower engine all the oil will just be pumped out the breather.
Red=breather
Blue=oil slinger
Yellow=carb
The oil slinger would be in the right place for this to work, but all the oil will be pumped out the breather into the carb.
Making a new manifold would be "fun" on one of those too.
Basically, it wont work.
Edit, an opposed twin? Aren't they pressure lube? that'd hell to convert. Don't do it.
