I love Tecumsehs
dave1701
Good for 100,000 Miles
MICHIGAN
Why are Tecumsehs always given such a bad rap? I accidentally left mine full of gas all winter and it just started right up. I would pick my Tecumseh 5hp over my dads Honda 5hp any day.
Bluethunder3320
mostly the carburetors suck. personally i dont have anything against them, they made pretty good engines. right up to the end, they were getting cheap IMO.
sideways
Unfinished projects king.
Perth, Western Australia
Tecumseh horse power per lb. exceeds B&S.
That's because Briggs are boat anchors, the least advanced engines know to humanity. No idea why so many of you guys like them, as far as I can tell it's just a patriotic American thing.
I've got one Tec, they're quite rare in Australia. It's a 2 stroke mower engine, brilliant design, very well thought out. Has a blocked carby though. :rolleyes:
I'd take a Tec carby over a Briggs one any day. 2c
I like my Tecumseh too, you wont hear me bad mouthing them.
Bluethunder3320
tricked out!!!
i must ask, why do almost EVERY race modified engine not have a recoil? i always see fancy shrouds over the recoil area.
Bluethunder3320
my tecumseh, i rebuilt it, but im not happy with the paint, going to eventually strip it and restore to factory.
an original pic:
HellSpawn
Wadena, Minnesota
race kart engines are generally started with a hand electric starter, Not sure why, but its probably just one less thing to worry about breaking @ the track.
Bluethunder3320
i would think a electric starter would be less reliable than a rope... but whatever! lol!
i didnt know that.
HellSpawn
Wadena, Minnesota
Also have to remember a lot of those race engines are hyped up and may have higher compression or lighter flywheels.. so starting by rope wouldn't be too fun.
tricked out!!!
Thanks,
HellSpawn was right. With super high compression, advanced timing, radical cam, no compression relief, running on methanol and 357cc. you cant just pull start my engine. I have to use a kart starter, they use a starter motor from a car engine with a motorcycle battery. The socket on the end fits on my flywheel nut and then you just push a button to crank it over.
After the engine starts you just let off the button and pull it off. There's a 1-way bearing on the starters shaft so it wont rip the whole thing out of your hands when the engine fires up. It took me a lot of practice and technique to learn how to start my engine without someone else there to help run the starter.
I'm not some rich spoiled guy, I shop around and buy most all my stuff (including kart 2 starters) used for a
much-much lower cost than new. Then I usually have to spend lots of time fixing my older stuff to work like new again.
karl
North east Ohio
My 10hp tecumseh died today. I am still morning the loss
It was abused beyond belief for 4 years and been on 4 tractors. It smokes alot has a rod knock and takes forever to start. If I put a bushing on the connecting rod and get new rings it will run again and Im thinking of doing it.
It held up as good as a briggs , I think they are even.
