Old Briggs and Stratton 3hp No Spark
jmadden91
Brisbane, Australia
Hi guys, I have an old 3hp B&S on my cylinder mower and after sitting in the shed for a few months it wont start. After having a look, I noticed it has no spark.. I pulled it apart and sanded the legs of the coil and magneto? But while it was apart a wire came off and im not sure where it goes.. I put it where I think it came from but it is still not sparking. Does anyone have any suggestions as to where the wire (pictured) goes? Or what else may be causing it not to spark?
Cheers guys
robbie
Osceola, Missouri
Isn't that the kill switch wire that kills the spark when you ground it?
Once you get the wire figured out, you could probably get some compressed air and blow enough grass out of your cooling fins to make an entire bale of hay.
LOL. My lawnmower always get so full of grass after I cut the lawn. I have to spend a good 5-10 minutes cleaning it up after I am finished. It is a pain in the a$$, but you gotta do it. I once has grass piled up next to my muffler, and it started burning. You can see from the photo of my mower how grass can get stuck between the muffler and the chasis.
Bluethunder3320
what is that tube?
turbo charger?:roflol:
i reccomend to the OP that he cleans the engine up first. grass stuck there can cause it to overheat pretty fast.
Bluethunder3320
Cheers guys
its probably a kill wire, that might be broken anyways.
heres a trick:
do NOT connect that wire. tape it off so that it doesnt ground or anything.
stick a credit card (or old gift card) under the mag and flywheel. tighten the bolts. this is done when the magnets in the flywheel are up top.
jareeB
heres a trick:
i use a 3" by 5" note card works really good
jmadden91
Brisbane, Australia
30+ Years old sideways.
Thanks for all the help guys, I terminated the wire and tried again, still no spark. Any other suggestions?
Haha and yep she needs a good clean
sexyvicta
you should find out what the magneto air gap should be on this engine and set it correctly. If you've just bolted it back on then you may have the gap way too big which would cause weak/no spark.
sideways
Unfinished projects king.
Perth, Western Australia
It's probably got points under the flywheel then, my 1979 and 1981 Briggs mower engines do. Does that wire go to under the flywheel?
If you got a set of feeler gauges the copper one is what the magneto air gap should be. Don't go as close as possible, when things vibrate and flex the mag will hit the flywheel. Back in reality, the gap doesn't matter too much, as long as it's reasonably close it'l be fine.
Thanks
Hayden
Bluethunder3320
points?????
look at the magneto............ its certainly electronic.
can you tell us the first 2 digits of the code stamped on the blower housing?
karl
North east Ohio
It is not a magnatron coil because it doesn't have that extra box on the coil ill bet $100 that it has points and condenser.
sexyvicta
.010" for magneto and is important as it affects timing.
.020" for points.
Run a match book striker between points to clean them.
yeh i set all mine to 10 thou.
how does it affect timing? i thought it would only affect strength of spark(not saying you're wrong i have no idea about this stuff and am curious). I have found if the gap is much greater than 10 thou, engines get hard to start and will run erratically
