Bluethunder3320
- Messages
- 5,677
- Reaction score
- 39
IT RUNS!!!! Video tonight!! It made tons of smoke then stopped hahah.
Shweet, that'll make a good skeeter-killer in the summer
Did you install a new piston and rings, or the old ones?
Success! Good job! Super cool smoking muffler too, you might wanna be careful as I've seen them light on fire before, all the old oil & fuel residue in there can be quite flammableNow how are you going to fit a clutch on it? Those governor motor shafts are such a stupid shape & size.
'ed off so i drilled it out. brill battery went up in smoke.
Well alrighty then, good job man!
LOL sounds like you're on the path to a lucrative career in small engine repair, you already sound exactly like every dude I've met who works in a mower shop! lol jk, keep up the good workthanks, i hope it runs for years to come. cant wait to get the generator back on and be done with the thing!
Who uses wheel bearing grease as assembly lube??
I've used moly grease as assembly lube, but only because nothing else was available. The best assembly lube is that ARP sauce, but it's extortionately expensive. You can always make your own, I think a 1 lb can of powdered moly is about $50 from these guys, plus a pint of good Mobil 1 synthetic oil. BAM instant assembly lube!Who uses wheel bearing grease as assembly lube??
lol well also i already had some since i needed some for my kart biuld.... the differential
You filled a differential with wheel bearing grease?
