make your clone carb adjustable?!
Looks just like the ones on older Tecumsehs. I think in order for that to work ideally, you'd have to swap in (or drill) a larger jet in order for that needle to regulate to the necessary mix. I like how it's advertised as a "jet". It's not. It's a needle. But still- A functional idea, I'm surprised that they're not in widespread use. Bit od a gouge on the price, though!
slideways
Probably made by NR racing and resold by those guys. To my knowledge no other motor's adjustable jet will swap into the threads. Which is why they are so expensive.. they are custom made to the clone.
slideways
Yea but it has to be totally leak proof and calibrated to a range of common jetting options for that motor.
I've yet to see anyone step up and make any cheaper.
Bluethunder3320
It cant be that hard to machine a 1 piece bowl retainer nut and jet... And just tapped for a adjustble needle in the middle..... I bet it costs whatever manufacturer who make that under a dollar and they sell it for 40.
Bluethunder3320
Only thing is i dont have a lathe. Some day! By then they will be completely necessary, imagine the future of the clones with the EPA involved.
Bluethunder3320
I know they are of course, but i mean like you can see how restrictive engines have got in the past 10 years, imagine another 10.
Russ2251
AZUSA:Powered by LAWN-BOY
It will get worse.
The current government would like nothing less than to stop the production of internal combustion engines completely.
We have already seen the demise of "L" head engines with 2 cycle power plants close behind.
Imagine having to pay for carbon credits just to have some fun on you kart.
All in the name of "man made global warming". Bad ****ing science from the start.
motor_head
expert garbage picker
sutherland IA
It will get worse.
and few scientists will publish results that disprove global warming if they do they loose funding
Bluethunder3320
people say that the ice caps are totally melting away, and i saw a chart in science class that said there will be no more ice at ALL period left in 2030. bs? and global warming? well it was a pretty cold winter if you ask me.
the coal burning power plants pollute the most. so while gas engines go away the government and EPA thinks its better to run cars off electricity that is made from burning coal?
id rather burn gas.....
also once people get electric cars, batteries dont last forever. where are these huge acid full batteries going?
fowler
Bullsbrook West Aus
in the sea :)
its all a load of crap
the winter u guys just had should prove to anyone that global warming is a load of poo
sure our climate is changing but we have nothing to do with it, there is nothing we can do to prevent change and it has always been changing since day 1 of creation
10 years? Its more like this all started back in 1970. I just researched the origins of the EPA and was totally surprised to learn it was a republican (Nixon) who pushed the agency into existence. I'd always figured we had some tree hugging democrat to blame for starting all this crap.
Badot
RANT ALERT:
Global warming, you say? If we're finding all these flooded underwater cities, that's proof that the sea was rising long before the industrial revolution. Unless we were having water asteroids hitting us, I think the only logical place it could have come from would be the ice caps. My opinion? Even if it's there, it's not our fault, at least as far as correlating to the pollution.
As far as electric cars go, I think we need to get our **** straight with gasoline cars first. Most cars have very poor aerodynamics, and are very heavy. And on top of that, there are many people who drive vehicles such as pickup trucks who never touch the beds, or SUVs which never have people nor cargo in the back.
As an example, the Metro XFi, using over 20 year old technology, got 53 city/ 58 hwy mpg, with a 1 ltr ~50hp engine. Its light weight gave it a comparable acceleration to a minivan, perfectly suitable for a commuter car. Then about 20 years later, here comes the Prius hybrid, toted as the 'omg it's so crazy efficient' car at the time, getting around 60mpg. Sure it's got a bit more power, but it's also a good bit heavier, not to mention a hell of a lot more expensive.
What I'd love to see would be a very low displacement engine, maybe 1 liter, with variable cam timing, tuned to run at lower RPMs like cars but balanced to go above the norm, giving it that extra power when needed. Throw in a small turbo too. Then direct inject it for that ultra-lean running ability. Sure, it's something new to design, but an engine like that could easily be made as powerful as our current economy engines, for about the same price (think less material, less to balance, etc), but have a lower size and weight, and have the ability to get absurdly high mileage while cruising.
robbie
Osceola, Missouri
If you want to be a big hero to the go kart and mini bike community, here's a step by step process.
Measure the thread size, length, diameter, etc, of the jet that's in the production carburetor on a Honda clone.
Do the calculations to figure out how to build a needle valve to replace the jet. Figure out the length, taper angle, thread pitch, etc.
Go to several machine shops and get quotes on a small production run. Find out how much it will cost to get 50, 100 or 250 units made. The more you order, the cheaper they get per piece, but the higher the total bill.
Cough up the money to get the parts made, then advertise them on go kart forum sites, sell on ebay, etc.
If you're making them yourself, you'll probably decide that you should make $25 profit every time you sell one because of all the back breaking labor you're doing, etc. If you get them made for you, it's all a question of return on your investment. You'll have to figure out how much it costs to get started, as well as long it takes to get all of your money back. Then sell them for whatever price you're comfortable with, but keep in mind that most people don't want to pay $40.
You'll have to get quotes to be sure, but I'm guessing that you can probably sell these for well under $40 each. I build amplifiers for musicians, and I get parts made at different shops. It's really nice because all you do is put in the order and within a few weeks you get your parts in the mail. But you have to be sure that your design isn't a piece of crap. It's no fun to get your parts and then figure out that something is wrong, and it's your fault. Maybe the best way to do it is to order the $40 needle valve and have a shop make clones of it.
