Tecumseh to Greyhound switch
redsox985
PA
It is relatively simple to do, but my point is that the clone will spin at the same RPM as the Tec. If you were willing to part with some speed in exchange for some extra starting torque, there's no reason to pull out the governor and void your warranty. You can mod the intake and exhaust to get some extra HP, but you probably won't reap the benefits without removing the gov., which IMO, is entirely unnecessary. Not only don't you need the extra RPMs, but pulling the gov. usually involves another $100+ dollars in stronger parts to ensure the extra 2000+ RPMs don't break any of the stock parts.
Bluethunder3320
how about a 125cc dirt bike engine?
the lifan's are around $400 new. plus they have manual's so you can shift.
Bluethunder3320
i think a billet rod is 60, plus you'd want a larger main jet, and valve springs. most likely a header and filter is already done by this point.
a billet flywheel is controversial, some guys here we were trying to submit it to myth busters, as far as i know it totally failed.
anyone have an update on that????
I gave up on pursuing it. It seems that 1) It wouldn't do anything for the TV ratings, as the average viewer niether knows of, nor cares about the exploding flywheel myth, and 2) That the "senior" members on their forum have the world worked out and can't possibly imagine why anyone would ever need an engine to spin over 3600RPM as the horsepower would drop exponentially and the world would come to a screaming halt. And yes, I'm bitter about it.
There's a lot of debate on this topic, few hard facts. Take a good, long look thru this forum, and form your own opinion. I have just removed the governor on my project engine. With stock valve springs and appropriate gearing, I have absolutely no fear whatsoever of catastrophic engine failure.
devino246
Official DIYGK Chem Nerd
Lynchburg, VA
I dont even want to be reminded of that:mad2:
Anyhoo- back on topic- Opinions are like bungholes- everybody's got one. If you're relatively new to the wonderful world of mechanics, I would normally advise you to run the engine stock until the warranty has expired. Then mess with it.
bighead
Pacific Northwest USA
Here is what I did. I had to get some spacers to line the clutches up. Simple mod the the throttle. Pretty basic swap. I think I had to mod plastic clutch guard as well.
Also when connecting a clone throttle cable. The clone you have to push the throttle not pull it. That is why you see the pivit arm in the pics.
Here is som pics. I did a few of these swaps already.
Not letting me pot some pics for some reason. I will get some better ones if you like.
bighead
Also if you remove the stock air box the choke lever can fall off. I made this tab to hold thge lever down. (the tab should be on the plastic part. It is off to the side in this pic)
Also notice the tab on the throttle rod arm that hooks to the carb. That rod will come out of the carb if not held down. I made another tab to hold that rod down.
If you keeping the airbox then you might have to look at other ways.
Good point, I'd forgotten about that. You can maje that tab or buy one. I decided to drill the choke pivot on the carb and run a screw into it to retain the choke lever.
