Building monster go kart from scratch
B man
Tecumseh FTW!
Oliver springs,Tn
have u even thought about getting a sled or bike engine? i mean its just much less work. saves money on your build.
This has been "mentioned" to the point of exhaustion. Can we just accept the fact that the OP is bent on using his PWC engine? Seriously. It's either going to work, or not. But he's going to try, and for that, I applaud him! :cheers2: It's an uphill battle, certainly not the cheapest or easiest. But the guy's rising to the challenge, and maybe it's just MY opinion, but I think it's time some folks here just drop the whole "go buy another engine", and start offering useful ideas. If he pulls it off, terrific! If not, well, it wasn't for lack of trying. Better this than come up with a whacko idea, stay with it only until it gets tough, and become a quitter. No?
hotrodchevy83
Hotrodchevy83
well it has really been cheaper actualy to use this engine lol i bought 8 jetskis last year for 200 bucks and four running motors and ebay some parts totaling to 100 bucks and scrap the hulls saved everything out of them and got about 200 on the hulls for scrap metal the scrap yard has a shredder and they take them so
Rustydog2010
NZ Nutta :|
New Zealand
If you are relying on the belt slippage as your so called 'clutch'. You can only figure the tension by trying it, it will be a dangerous process..
Jeremy.
bighead
Pacific Northwest USA
I brought this subject up at work today with the company mechanic hot rod freak. He said the something about the crank bearings not be able to handle loads or something like that. Bearing are small for the engine just has to run a prop. On a kart he thinks the bearing would fail pretty fast from the load.
Just thought I would mention that here.
fowler
Bullsbrook West Aus
thats interesting
i guess it makes sense
if u have 4 of these engines u should at least sell one for a bike engine
also u dont need springs. look atthe tensioner clucth on the PTO engine
no springs but a solid linkage as it is firmer
i should proberly point out that PTO engine wasnt made my me or dad with junk parts it was made by an engineering company (stewards engineering)
CriticalMass
East Bay CA
It would be engine specific I think but I read up on the crank bearings being weak. A guy tore his apart and found out the crank bearings were similar to other crank bearings that handle loads. He said it was a non issue for him.
hotrodchevy83
Hotrodchevy83
thats why i have the factory rubber coupling and it being gear reducted with pulleys and sprockets
redsox985
PA
Off topic here, but would you mind compiling your responses into one post? It just makes it easier to read. To help organize you can use multi-quote or just hit enter twice to show a new thought. Multi-quote is the little quote marks next to the quote button. Just click the ones you want, then click quote on the final person you wish to quote. It just looks neater than 3 posts each a minute after the other.
I second the motion. Would keep things neater and easier to follow.
Now, back on topic. Regarding the tensioner- I have already stated that I don't think the belts will live long. But having said that, I think you do want to use springs. Ultimately, I am assuming you intend to have a clutch pedal. When you release the pedal, you want the belts to tension and take up drive. For this, you will need spring tension, and probably a fair bit. I have heard of guys using springs from a trampoline or hideaway sofa for this. You may also want to create some sort of mechanism wherein you can push the pedal and mechanically "lock" the tensioner system in the "loose" position. Doing so will allow you to idle/warm up the engine without having to stand on the pedal the whole time.
fowler
Bullsbrook West Aus
hey fowler who said i was using junk parts lol
theoreically u are
but what i said is that engine wasnt made outta junk. i said i so u would respect the design more
also i too think u need springs but still have a solid linkage
just use a spring attached to the tensioner to keep it in place
if u look at the pto engine there is no spring because the geometry is right, we just pull the lever down (with no effot) and leave it
for your purpose u will need a spring on the tensioner arm to engage it
