DCProductions
Cockney Ragamuffin
1st, does the air filter HAVE to go all the way over the adapter? If you can, scoot the air filter forward a little and hose clamp it on out a little farther. Another option is drilling into the back side of the adapter, the side facing the carb. From either of these points you could run a bracket up to the level of the arm and attach the fitting there.
I think I get what you're saying about the frame, but I think you need to attach it to a front piece of the frame (in front of the engine). Am I misunderstanding you?
