karts4life
- Messages
- 16
- Reaction score
- 0
Hey, when I try pulling my pull start it will pull out but then be stuck. The only way it will recoil is if I unscrew the engine case. The coil system seems to be slipping away from the actual engine, i.e. it is not the coil itself, but its inability to stay attached to the flywheel. How can I eliminate this problem? nothing seems to be broken, just when I give it a good tug it will just stop and not retract or slip off the flywheel. help?
